推荐阅读PSoC1 入门应用笔记
7267|16
 楼主| jxin 发表于 2012-7-14 15:14 | 显示全部楼层 |阅读模式
AN75320 - Getting Started with PSoC® 1
The Cypress PSoC 1 (Programmable System-on-Chip) integrates a microcontroller with programmable analog and digital peripherals. Use the AN75320 application note to get started on the capabilities of PSoC 1 devices and the PSoC Designer development environment used to configure and program those devices.
http://china.cypress.com/?rID=58639]
AN74170 - PSoC 1 Analog Structure and Configuration with PSoC Designer™
AN74170 explains the analog structure of standard PSoC® 1 devices and how the global analog parameters affect many of the analog user modules. The in-depth explanation of the Analog block array will help you utilize the flexible analog system of this mixed signal microcontroller effectively. A list of commonly made mistakes and suggestions for rectification is also provided.
http://china.cypress.com/?rID=59181]
AN73212 - Debugging with PSoC® 1
AN73212 introduces the elements of the PSoC 1 debugger system and explains how to configure and use them effectively. It provides you with several common debugging techniques and a troubleshooting guide to help solve common problems, such as stack overflow and memory corruption.
http://china.cypress.com/?rID=57555]
Go_PSoC 发表于 2012-7-14 20:16 | 显示全部楼层
beiwaroad 发表于 2012-7-16 09:55 | 显示全部楼层
貌似非中文啊
xichengmadia 发表于 2012-7-16 10:08 | 显示全部楼层
由此可知为什么公司招人都要英语好的了
engtafanzhuan 发表于 2012-7-16 10:40 | 显示全部楼层
收了,多谢楼主
chao11yue 发表于 2012-7-16 10:49 | 显示全部楼层
学习下载中
 楼主| jxin 发表于 2012-7-20 11:18 | 显示全部楼层
顶起来。。。。
Go_PSoC 发表于 2012-7-20 22:58 | 显示全部楼层
帮你顶
G21372 发表于 2012-7-26 22:57 | 显示全部楼层
好全的资料,真心感谢楼主
huigoushang 发表于 2012-7-26 23:10 | 显示全部楼层
好东西,只可惜是英文的
u880 发表于 2012-7-26 23:25 | 显示全部楼层
都下载了,多谢楼主
taihezhibanh 发表于 2012-7-26 23:33 | 显示全部楼层
先收藏了,以后我有好东西也会传上来分享给大伙的
heibaiyinjiag 发表于 2012-7-26 23:42 | 显示全部楼层
太感谢楼主了
sishangcine 发表于 2012-7-26 23:54 | 显示全部楼层
多谢分享
zgsxhzac 发表于 2012-7-27 00:05 | 显示全部楼层
真是好东西,多谢了
shibalihuandao 发表于 2012-7-27 00:12 | 显示全部楼层
英文的,有难度
waterlaotou 发表于 2012-7-27 09:16 | 显示全部楼层
谢谢楼主,我想看看关于PSoC1里数字模块的配置,有没有相关资料啊。还有引脚的逻辑功能配置,谢啦~
