2812烧写问题求助
5525|6
 楼主| hxg80 发表于 2007-7-19 14:34 | 显示全部楼层 |阅读模式
&nbsp;开发工具是CCS3.1,FLASH烧写工具是TI为其提供的插件。在烧写过程中出现如下提示:<br /><br />Target&nbsp;halted&nbsp;during&nbsp;Flash&nbsp;operation.<br />Flash&nbsp;operation&nbsp;aborted.<br />Erase/Program/Verify&nbsp;Operation&nbsp;failed<br />****&nbsp;End&nbsp;Erase/Program/Verify&nbsp;Operation.&nbsp;***<br />An&nbsp;invalid&nbsp;Flash&nbsp;API&nbsp;Interface&nbsp;file&nbsp;has&nbsp;been<br />been&nbsp;loaded&nbsp;onto&nbsp;the&nbsp;target.&nbsp;Please&nbsp;verify&nbsp;that<br />the&nbsp;file&nbsp;selected&nbsp;in&nbsp;the&nbsp;Flash&nbsp;Programmer&nbsp;Settings<br />is&nbsp;a&nbsp;valid&nbsp;Flash&nbsp;API&nbsp;Interface&nbsp;file.<br />Erase/Program/Verify&nbsp;Operation&nbsp;failed<br />****&nbsp;End&nbsp;Erase/Program/Verify&nbsp;Operation.&nbsp;***<br /><br />&nbsp;&nbsp;&nbsp;我用的API&nbsp;interface&nbsp;file&nbsp;&nbsp;是:&nbsp;FlashAPIInterface2812V2_10.out&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;我DSP的完整型号是:TMS320F2812PGFA CG-6AA7X5W&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;
 楼主| hxg80 发表于 2007-7-19 14:55 | 显示全部楼层
re
大哥们,给点建议吧,我已经郁闷一天拉!
yning 发表于 2007-7-19 16:37 | 显示全部楼层
闭锁
这款芯片出现过锁死的现象!<br />用的什么仿真器?<br />欢迎和我联系!<br />
wolfang8 发表于 2007-7-19 17:45 | 显示全部楼层
ccs
最好用ccs&nbsp;c2000进行烧写
nxy825715 发表于 2007-7-23 09:23 | 显示全部楼层
个人见解:
楼主所用的插件是CCS2000&nbsp;V2.2版本的。
chatter 发表于 2007-9-6 19:14 | 显示全部楼层
RE
问题解决没,是不是CMD文件的问题?
nakatao 发表于 2007-9-11 19:41 | 显示全部楼层
RE
检查一下CMD,载到RAM&nbsp;试一下
