STM32和PCA82C251通讯不了,急...
3165|3
 楼主| lightour 发表于 2012-9-27 15:03 | 显示全部楼层 |阅读模式
这些天一直在调试CAN,之前开发板上用得是VP230,双CAN可以在正常模式下通讯,我项目要用到PCA82C251(CAN收发器),用PCA82C251把VP230替换掉,就是通讯不了。电路图如下:
 楼主| lightour 发表于 2012-9-27 15:05 | 显示全部楼层
程序是:
void CAN_Config(void)
  /* CAN register init */
  CAN_DeInit(CAN1);
  CAN_DeInit(CAN2);
  CAN_StructInit(&CAN_InitStructure);
  /* CAN1 cell init */
  CAN_InitStructure.CAN_TTCM = DISABLE;
  CAN_InitStructure.CAN_ABOM = DISABLE;
  CAN_InitStructure.CAN_AWUM = DISABLE;
  CAN_InitStructure.CAN_NART = DISABLE;
  CAN_InitStructure.CAN_RFLM = DISABLE;
  CAN_InitStructure.CAN_TXFP = DISABLE;
  CAN_InitStructure.CAN_Mode = CAN_Mode_Normal;
  CAN_InitStructure.CAN_SJW = CAN_SJW_1tq;
  CAN_InitStructure.CAN_BS1 = CAN_BS1_3tq;
  CAN_InitStructure.CAN_BS2 = CAN_BS2_5tq;
  CAN_InitStructure.CAN_Prescaler = 4;
  CAN_Init(CAN1, &CAN_InitStructure);
  CAN_Init(CAN2, &CAN_InitStructure);
  /* CAN1 filter init */
  CAN_FilterInitStructure.CAN_FilterNumber = 0;
  CAN_FilterInitStructure.CAN_FilterMode = CAN_FilterMode_IdMask;
  CAN_FilterInitStructure.CAN_FilterScale = CAN_FilterScale_32bit;
  CAN_FilterInitStructure.CAN_FilterIdHigh = 0x0000;
  CAN_FilterInitStructure.CAN_FilterIdLow = 0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdHigh = 0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdLow = 0x0000;
  CAN_FilterInitStructure.CAN_FilterFIFOAssignment = 0;
  CAN_FilterInitStructure.CAN_FilterActivation = ENABLE;
  CAN_FilterInit(&CAN_FilterInitStructure);
  /* CAN2 filter init */
  CAN_FilterInitStructure.CAN_FilterNumber = 14;
  /* Transmit */
  TxMessage.StdId = 0x321;
  TxMessage.ExtId = 0x01;
  TxMessage.RTR = CAN_RTR_DATA;
  TxMessage.IDE = CAN_ID_STD;
  TxMessage.DLC = 1;
 楼主| lightour 发表于 2012-9-27 15:06 | 显示全部楼层
中断:
void CAN1_RX0_IRQHandler(void)
  CAN_Receive(CAN1, CAN_FIFO0, &RxMessage);
  if ((RxMessage.StdId == 0x321)&&(RxMessage.IDE == CAN_ID_STD)&&(RxMessage.DLC == 1)&&(RxMessage.Data[0] == 0xAA))
    LED_Display(0x03);
  else
    LED_Display(0x05);
  * @brief  This function handles CAN2 RX0 Handler.
  * @param  None
  * @retval None
void CAN2_RX0_IRQHandler(void)
  CAN_Receive(CAN2, CAN_FIFO0, &RxMessage);
  if ((RxMessage.StdId == 0x321)&&(RxMessage.IDE == CAN_ID_STD)&&(RxMessage.DLC == 1)&&(RxMessage.Data[0] == 0x55))
    LED_Display(0x04);
  else
    LED_Display(0x05);
深夜星空 发表于 2013-5-21 20:59 | 显示全部楼层
请问楼主,这个问题解决了吗?我也遇到此类问题了,马上毕设就要答辩了,着急
