| 用的是内部电压参考,2.048V,当输入悬空或接地时。转换结果是 0x000109左右,而且基本上高12~16位不变,低位变化幅度也不大,貌似正常,但是输入一个零点几伏电压之后,结果就变化成0xFDDBXX  左右,高位字节也基本不变,但是转换的结果与实际不匹配,大于不知道是为什么。
 下面是代码,求解答。
 #include"ADS1248.h"
 uchar idata channel_0[3];
 uchar idata channel_1[3];
 uchar idata channel_2[3];
 uchar idata channel_3[3];
 uchar idata channel_4[3];
 void w_ads(uchar x,uchar y) //x寄存器地址,y寄存器内容
 uchar i,RXBUF;
 RXBUF = 128;
 for(i = 8;i;i--)
 adsclk = 1;
 delay_us(2);
 adsdin = (x&RXBUF)?1:0;
 delay_us(2);
 RXBUF = RXBUF>>1;
 adsclk = 0;
 delay_us(2);
 for(i = 8;i;i--)
 adsclk = 1;
 delay_us(2);
 adsdin = 0;
 delay_us(2);
 adsclk = 0;
 delay_us(2);
 RXBUF = 128;
 for(i=8;i;i--)
 adsclk = 1;
 delay_us(2);
 adsdin = (y&RXBUF)?1:0;
 delay_us(2);
 RXBUF = RXBUF>>1;
 adsclk = 0;
 delay_us(2);
 void start_ad()
 uchar channel[3];
 uchar i,RXBUF;
 RXBUF = 128;
 for(i = 8;i;i--)
 adsclk = 1;
 delay_us(2);
 adsdin = (0x06&RXBUF)?1:0;
 delay_us(2);
 RXBUF = RXBUF>>1;
 adsclk = 0;
 delay_us(2);
 delay_ms(20);
 //-----------选择通道,配置寄存器----------
 w_ads(MUX0,29);    //burnout current source off  (default)
 w_ads(VBIAS,0);   // Bias voltage not enabled (default)
 w_ads(MUX1,0x30); // Internal oscillator in use,Internal reference is always on,Normal operation (default)
 w_ads(SYS0,2);    // gain of the PGA = 1(default),output data rate of the ADC = 20SPS
 w_ads(OFC0,0);    //--------------------------------------------------------
 w_ads(OFC1,0);    // register value of 000000h provides no offset correction
 w_ads(OFC2,0);    //--------------------------------------------------------
 w_ads(FSC0,0);    //--------------------------------------------------------
 w_ads(FSC1,0);    // normalized to 1.0 at code 400000h
 w_ads(FSC2,0x40); //------------------------------------------------------
 w_ads(IDAC0,0);      //DOUT/DRDY pin functions only as Data Out (default)
 w_ads(IDAC1,0xCC);//DISCONNNECTED (default)
 w_ads(GPIOCFG,0); //The pin is used as an analog input (default)
 w_ads(GPIODIR,0); //The GPIO is an output (default)
 //-------------start-------------
 adstart = 1;
 delay_us(1);
 adstart = 0;
 // delay_ms(60);
 while(adsrdy);
 rdata_ads(channel_0);
 void rdata_ads(uchar channeldata[3])
 uchar i,j,BUF;
 BUF = 128;
 //------写读命令------
 for(i=8;i;i--)
 adsclk = 1;
 delay_us(2);
 adsdin = (0x12&BUF)?1:0;
 delay_us(2);
 BUF = BUF>>1;
 adsclk = 0;
 delay_us(1);
 //-------读出---------
 for(i=8;i;i--)
 adsclk = 1;
 delay_us(2);
 j = adsdout?1:0;
 delay_us(2);
 channeldata[0] = channeldata[0]<<1;
 channeldata[0] = channeldata[0]|j;
 adsclk = 0;
 delay_us(2);
 for(i=8;i;i--)
 adsclk = 1;
 delay_us(2);
 j = adsdout?1:0;
 delay_us(2);
 channeldata[1] = channeldata[1]<<1;
 channeldata[1] = channeldata[1]|j;
 adsclk = 0;
 delay_us(2);
 for(i=8;i;i--)
 adsclk = 1;
 delay_us(2);
 j = adsdout?1:0;
 delay_us(2);
 channeldata[2] = channeldata[2]<<1;
 channeldata[2] = channeldata[2]|j;
 adsclk = 0;
 delay_us(2);
