调试DDR2弹出的错误
2987|5
 楼主| chenbignster 发表于 2012-12-24 11:04 | 显示全部楼层 |阅读模式
ERROR:Place:1073 - Placer was unable to create RPM[IOB_RPMs] for the component
   DDR2_LDQS_N of type IOB for the following reason.
   The reason for this issue:
   Some of the logic associated with this structure is locked. This should cause
   the rest of the logic to be locked.A problem was found at site PAD202 where
   we must place IOB IO_x_x_x_x_x_x_x_x_x_x in order to satisfy the relative
   placement requirements of this logic.  IOB DDR2DATA<11> appears to already be
   placed there which makes this design unplaceable.  The following components
   are part of this structure:
约束中我已添加了红色部分,是参照IP核生成的例子中,不知道约束还要添加什么??
 楼主| chenbignster 发表于 2012-12-24 11:05 | 显示全部楼层
百度与GOOGLE都没有ERROR 1073,应当是个小问题的。
GoldSunMonkey 发表于 2012-12-24 21:55 | 显示全部楼层
感觉分配的管脚有问题
评分
参与人数 1威望 +1 收起 理由
chenbignster + 1 赞一个!
查看全部评分
 楼主| chenbignster 发表于 2012-12-26 09:50 | 显示全部楼层
要用MIG自动生成的管脚名,像MCB3_DRAM_****,不知道怎么不能用自己的命名,暂时就用自动生成的名字调试吧,不能影响调试DDR2的进度
lwq030736 发表于 2012-12-26 11:31 | 显示全部楼层
管脚电平类型设错了吧?你设成SSTL-18 Class I再试试
GoldSunMonkey 发表于 2012-12-26 22:42 | 显示全部楼层
