CCS3.3怎样查看C生成的汇编程序
11775|12
 楼主| fuqiang4343 发表于 2012-12-29 13:53 | 显示全部楼层 |阅读模式
我在进行程序优化,每次必须将程序下载到DSP中才能看到最新的汇编程序。有没有什么方便的办法能看到C生成的汇编程序
 楼主| fuqiang4343 发表于 2012-12-29 16:04 | 显示全部楼层
查到办法,可以用软件仿真。但是有另外一个问题,下载程序时提示
我的CMD文件
// TI File $Revision: /main/4 $
// Checkin $Date: November 9, 2009   15:09:12 $
// FILE:        F2808.cmd
// TITLE:        Linker Command File For F2808 Device
// $TI Release: 2803x C/C++ Header Files V1.21 $
// $Release Date: December 1, 2009 $
// For Code Composer Studio V2.2 and later
// In addition to this memory linker command file,
// add the header linker command file directly to the project.
// The header linker command file is required to link the
// peripheral structures to the proper locations within
// the memory map.
// The header linker files are found in <base>\DSP2803x_Headers\cmd
// For BIOS applications add:      DSP2803x_Headers_BIOS.cmd
// For nonBIOS applications add:   DSP2803x_Headers_nonBIOS.cmd
// For Code Composer Studio prior to V2.2
// 1) Use one of the following -l statements to include the
// header linker command file in the project. The header linker
// file is required to link the peripheral structures to the proper
// locations within the memory map                                    */
/* Uncomment this line to include file only for non-BIOS applications */
/* -l DSP2803x_Headers_nonBIOS.cmd */
/* Uncomment this line to include file only for BIOS applications */
/* -l DSP2803x_Headers_BIOS.cmd */
/* 2) In your project add the path to <base>\DSP2803x_headers\cmd to the
   library search path under project->build options, linker tab,
   library search path (-i).
/* Define the memory block start/length for the F28035
   PAGE 0 will be used to organize program sections
   PAGE 1 will be used to organize data sections
   Notes:
         Memory blocks on F2803x are uniform (ie same
         physical memory) in both PAGE 0 and PAGE 1.
         That is the same memory region should not be
         defined for both PAGE 0 and PAGE 1.
         Doing so will result in corruption of program
         and/or data.
         L0 memory block is mirrored - that is
         it can be accessed in high memory or low memory.
         For simplicity only one instance is used in this
         linker file.
         Contiguous SARAM memory blocks or flash sectors can be
         be combined if required to create a larger memory block.
MEMORY
PAGE 0:    /* Program Memory */
           /* Memory (RAM/FLASH/OTP) blocks can be moved to PAGE1 for data allocation */
   RAML0       : origin = 0x008000, length = 0x000800     /* on-chip RAM block L0 */
   RAML1       : origin = 0x008800, length = 0x000400     /* on-chip RAM block L1 */
   OTP         : origin = 0x3D7800, length = 0x000400     /* on-chip OTP */
   FLASHH      : origin = 0x3E8000, length = 0x00D000     /* on-chip FLASH */
//   FLASHG      : origin = 0x3EA000, length = 0x002000     /* on-chip FLASH */
//   FLASHF      : origin = 0x3EC000, length = 0x002000     /* on-chip FLASH */
//   FLASHE      : origin = 0x3EE000, length = 0x002000     /* on-chip FLASH */
//   FLASHD      : origin = 0x3F0000, length = 0x002000     /* on-chip FLASH */
//   FLASHC      : origin = 0x3F2000, length = 0x002000     /* on-chip FLASH */
   FLASHA      : origin = 0x3F5000, length = 0x002F80     /* on-chip FLASH */
   CSM_RSVD    : origin = 0x3F7F80, length = 0x000076     /* Part of FLASHA.  Program with all 0x0000 when CSM is in use. */
   BEGIN       : origin = 0x3F7FF6, length = 0x000002     /* Part of FLASHA.  Used for "boot to Flash" bootloader mode. */
   CSM_PWL_P0  : origin = 0x3F7FF8, length = 0x000008     /* Part of FLASHA.  CSM password locations in FLASHA */
   IQTABLES    : origin = 0x3FE000, length = 0x000B50     /* IQ Math Tables in Boot ROM */
   IQTABLES2   : origin = 0x3FEB50, length = 0x00008C     /* IQ Math Tables in Boot ROM */
   IQTABLES3   : origin = 0x3FEBDC, length = 0x0000AA          /* IQ Math Tables in Boot ROM */
   ROM         : origin = 0x3FF27C, length = 0x000D44     /* Boot ROM */
   RESET       : origin = 0x3FFFC0, length = 0x000002     /* part of boot ROM  */
   VECTORS     : origin = 0x3FFFC2, length = 0x00003E     /* part of boot ROM  */
PAGE 1 :   /* Data Memory */
           /* Memory (RAM/FLASH/OTP) blocks can be moved to PAGE0 for program allocation */
           /* Registers remain on PAGE1                                                  */
   BOOT_RSVD(I)   : origin = 0x000000, length = 0x000050     /* Part of M0, BOOT rom will use this for stack */
   RAMM0(I)       : origin = 0x000050, length = 0x0003B0     /* on-chip RAM block M0 */
   RAMM1(I)       : origin = 0x000400, length = 0x000400     /* on-chip RAM block M1 */
   RAML2(I)       : origin = 0x008C00, length = 0x000400     /* on-chip RAM block L2 */
   RAML3(I)       : origin = 0x009000, length = 0x001000     /* on-chip RAM block L3 */
   FLASHB(I)      : origin = 0x3F4000, length = 0x002000     /* on-chip FLASH */
/* Allocate sections to memory blocks.
   Note:
         codestart user defined section in DSP28_CodeStartBranch.asm used to redirect code
                   execution when booting to flash
         ramfuncs  user defined section to store functions that will be copied from Flash into RAM
SECTIONS
   /* Allocate program areas: */
   .cinit              : > FLASHA      PAGE = 0
   .pinit              : > FLASHA,     PAGE = 0
   .text               : > FLASHH      PAGE = 0
   codestart           : > BEGIN       PAGE = 0
   ramfuncs            : LOAD = FLASHA,
                         RUN = RAML0,
                         LOAD_START(_RamfuncsLoadStart),
                         LOAD_END(_RamfuncsLoadEnd),
                         RUN_START(_RamfuncsRunStart),
                         PAGE = 0
   csmpasswds          : > CSM_PWL_P0  PAGE = 0
   csm_rsvd            : > CSM_RSVD    PAGE = 0
   /* Allocate uninitalized data sections: */
   .stack              : > RAMM0       PAGE = 1
   .ebss               : > RAML3       PAGE = 1
   .esysmem            : > RAML2       PAGE = 1
   /* Initalized sections go in Flash */
   /* For SDFlash to program these, they must be allocated to page 0 */
   .econst             : > FLASHA      PAGE = 0
   .switch             : > FLASHA      PAGE = 0
   /* Allocate IQ math areas: */
   IQmath              : > FLASHA      PAGE = 0            /* Math Code */
   IQmathTables        : > IQTABLES,   PAGE = 0, TYPE = NOLOAD
  /* Uncomment the section below if calling the IQNexp() or IQexp()
      functions from the IQMath.lib library in order to utilize the
      relevant IQ Math table in Boot ROM (This saves space and Boot ROM
      is 1 wait-state). If this section is not uncommented, IQmathTables2
      will be loaded into other memory (SARAM, Flash, etc.) and will take
      up space, but 0 wait-state is possible.
   IQmathTables2    : > IQTABLES2, PAGE = 0, TYPE = NOLOAD
              IQmath.lib<IQNexpTable.obj> (IQmathTablesRam)
    /* Uncomment the section below if calling the IQNasin() or IQasin()
    IQmathTables3    : > IQTABLES3, PAGE = 0, TYPE = NOLOAD
               IQmath.lib<IQNasinTable.obj> (IQmathTablesRam)
   /* .reset is a standard section used by the compiler.  It contains the */
   /* the address of the start of _c_int00 for C Code.   /*
   /* When using the boot ROM this section and the CPU vector */
   /* table is not needed.  Thus the default type is set here to  */
   /* DSECT  */
   .reset              : > RESET,      PAGE = 0, TYPE = DSECT
   vectors             : > VECTORS     PAGE = 0, TYPE = DSECT
// End of file.
 楼主| fuqiang4343 发表于 2013-1-7 14:13 | 显示全部楼层
把CMD换成RAM的文件,但是又有空间不够的问题。把程序分配到不存在的空间,编译没问题但是生成的反汇编看不到
neufeifatonju 发表于 2013-1-8 23:32 | 显示全部楼层
帮顶一下,最近正要学习C2000
hawksabre 发表于 2013-1-9 21:35 | 显示全部楼层
这一块真心不知道啊   没有做过这一块   呵呵  帮你顶一个   哦呵呵
leadman 发表于 2013-1-9 23:28 | 显示全部楼层
在CCS3.3中查看C生成的汇编程序,原来没弄过,过来取取经
wenjun_wang86 发表于 2013-12-18 11:28 | 显示全部楼层
需要在DEBUG模式下,才能看到汇编对照的C代码。报错的话可能是因为编译选项不对。
mmbs 发表于 2013-12-19 11:25 | 显示全部楼层
不知道楼主看汇编要做什么呢?
调试的时候,好像会出现的 。
lkl0305 发表于 2014-4-7 21:14 | 显示全部楼层
正在学习:)
Steaven 发表于 2014-5-6 09:56 | 显示全部楼层
连接仿真器,把程序烧到MCU,然后在CCS中点击:View->Mixed Source/ASM,查看C和汇编的混合视图,逐语句对应的。
jdliuhuihong 发表于 2016-12-16 16:17 | 显示全部楼层
个人签名:本人什么都会!就两样不会,这也不会那也不会。
