stm32f103C8T6的UART2配置,现在配好后UART2有输出 但是输出不对。请高手指点啊
USART2_SendData(0x80);时串口调试助手收到 00
送00 收到00,送01 收到03, 送0xa1收到0x83, 送0x10收到0x40
配置如下
void GPIO_Configuration(void)
RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA | RCC_APB1Periph_USART2 | RCC_APB2Periph_GPIOB , ENABLE ); //这里如果没有 RCC_APB2Periph_GPIOA 就没输出
// RCC_APB1PeriphClockCmd( RCC_APB1Periph_USART2, ENABLE );
/* Configure USART2 Tx (PA.02) as alternate function push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; // 选中管脚2
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; // 复用推挽输出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz; // 最高输出速率50MHz
GPIO_Init(GPIOA, &GPIO_InitStructure); // 选择A端口
/* Configure USART2 Rx (PA.03) as input floating */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3; //选中管脚3
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //浮空输入
GPIO_Init(GPIOA, &GPIO_InitStructure); //选择A端口
/*I2C I/O口配置 PB6,PB7 */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
/*按键输入 I/O口配置 PB14 */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
/* Configure LED (PB.8) as PP OUT */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; //选中管脚8
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推拉输出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz; // 最高输出速率2MHz
GPIO_Init(GPIOB, &GPIO_InitStructure); //选择B端口
void USART2_Configuration(void)
USART_InitTypeDef USART_InitStructure;
USART_ClockInitTypeDef USART_ClockInitStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE ); //RCC_APB1Periph_TIM2 |
USART_ClockInitStructure.USART_Clock = USART_Clock_Disable; // 时钟低电平活动
USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low; // 时钟低电平
USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge; // 时钟第二个边沿进行数据捕获
USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable; // 最后一位数据的时钟脉冲不从SCLK输出
/* Configure the USART2 synchronous paramters */
USART_ClockInit(USART2, &USART_ClockInitStructure); // 时钟参数初始化设置
USART_InitStructure.USART_BaudRate = 9600; // 波特率为:9600
USART_InitStructure.USART_WordLength = USART_WordLength_8b; // 8位数据
USART_InitStructure.USART_StopBits = USART_StopBits_1; // 在帧结尾传输1个停止位
USART_InitStructure.USART_Parity = USART_Parity_No ; // 奇偶失能
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; // 硬件流控制失能
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; // 发送使能+接收使能
/* Configure USART2 basic and asynchronous paramters */
USART_Init(USART2, &USART_InitStructure);
/* Enable USART2 */
USART_ClearFlag(USART2, USART_IT_RXNE); //清中断,以免一启用中断后立即产生中断
USART_ITConfig(USART2,USART_IT_RXNE, ENABLE); //使能USART2中断源
USART_Cmd(USART2, ENABLE); //USART2总开关:开启
