请教 读按键程序.
2159|2
 楼主| avocationA 发表于 2008-5-11 14:06 | 显示全部楼层 |阅读模式
#include "keyScan.h"
#include <reg51.h>
#define KEY_BOARD P1
#define DELAY_VALUE 500
延时子程序
void delay()
 unsigned short data i;
 for(i = DELAY_VALUE;i != 0;i--);
取得当前按键码
unsigned char getKey()
 unsigned char data keyState,scan,count,keyCode;
 keyCode = 0xff;
 /*是否有键按下*/
 KEY_BOARD = 0xf0;
 keyState = KEY_BOARD | 0x0f;
 keyState = ~keyState;
 if(!keyState) return keyCode;
 delay();
 KEY_BOARD = 0xf0;
 /*键盘扫描*/
 scan = 0xfe;
 for(count = 0;count < 4;count++){
     KEY_BOARD = scan;
     scan <<= 1;
     scan ++;
     keyState = KEY_BOARD & 0xf0;
     if(keyState){
          switch(keyState){
          case 0xe0:
               keyCode = count;
               break;
          case 0xd0:
               keyCode = count + 4;
               break;
          case 0xb0:
               keyCode = count + 8;
               break;
          case 0x70:
               keyCode = count + 12;
               break;
     if(keyCode != 0xff) break;
 //等到按键松开
 do{
    KEY_BOARD = 0xf0;
 }while(keyState);
 return keyCode;
 楼主| avocationA 发表于 2008-5-11 14:10 | 显示全部楼层
keyState = KEY_BOARD | 0x0f;这句好像没有意义了吧,?
上面那三行不懂,不知道是做什么用的?
keyState 的值好像被覆盖了那么keyState = KEY_BOARD | 0x0f;这句好像没有意义了吧,?
一级菜鸟 发表于 2008-5-11 14:41 | 显示全部楼层
没有意义?
这段代码是挺臭,不过keyState = KEY_BOARD | 0x0f并非没有意义,它屏蔽了P1的高4位。
