新手求助调用中断延时不能运行
1367|0
 楼主| philzhao 发表于 2013-1-16 21:16 | 显示全部楼层 |阅读模式
#include<pic.h>//16f877a
__CONFIG(0x1832);//晶体是11。0592
#define uint  unsigned int
#define uchar  unsigned char
  uchar result;
  uchar num;
void init()
  TRISB=0xff;
  TRISC=0x00;
  PORTB=0xff;
  PORTC=0x00;
  OPTION_REG=0x07;
  INTCON=0xa0;
  TMR0=61;
  void interrupt time0()
T0IF=0;
TMR0=61;
num++;
void delay()
while(num>=60)
num=0;
void main()
init();
while(1)
PORTC=0xff;
delay();
PORTC=0x00;
