望各位高人指教!
2366|7
 楼主| 雁舞白沙 发表于 2008-8-20 10:31 | 显示全部楼层 |阅读模式
ic, iic, sd, AD, TE
问题:此模拟IIC,在413上可以运行,读取和写入数据正常,但是在123上就不可以!
望各位高人指教!
#include <GLOBAL.h>
#include <stdlib.h>
#include <stdbool.h>
#include <msp430x12x.h>
#define BIT0                (0x0001)
#define BIT1                (0x0002)
#define BIT2                (0x0004)
#define IicWpDirOut           P1DIR |=  BIT2
#define IicWpDirIn            P1DIR &= ~BIT2
#define IicWpHig              P1OUT |=  BIT2
#define IicWpLow              P1OUT &= ~BIT2
#define IicSclDirOut          P1DIR |=  BIT1
#define IicSclDirIn           P1DIR &= ~BIT1
#define IicSclHig             P1OUT |=  BIT1
#define IicSclLow             P1OUT &= ~BIT1
#define IicSdaDirOut          P1DIR |=  BIT0
#define IicSdaDirIn           P1DIR &= ~BIT0
#define IicSdaHig             P1OUT |=  BIT0
#define IicSdaLow             P1OUT &= ~BIT0
#define IicSdaInSt            P1IN  &   BIT0
bool AckErr;
unsigned char TimeDelay=10;
//-----***-IIC延时(一个nop是纳秒 10个大概是1.67微秒大概总线速度在300K符合IIC在写状态下400K的要求)-***-----//
void IicInit(void)
    IicWpDirOut;
    IicSdaDirOut;
    IicSclDirOut;
    IicWpHig;
    IicSdaHig;
    IicSclHig;
//-----***-IIC启示-***-----//
void IicStart(void)
      IicSdaHig;//IicSda=1;
    Delay(TimeDelay);
    IicSclHig;//IicScl=1;
    Delay(TimeDelay);
    IicSdaLow;//IicSda=0;
    Delay(TimeDelay);
    IicSclLow;//IicScl=0;
    Delay(TimeDelay);
//-----***-IIC停止-***-----//
void IicStop(void)
    Delay(TimeDelay);
    Delay(TimeDelay);
    Delay(TimeDelay);
//-----***-IIC错误-***-----//
void IicErr(void)
    AckErr=1;
    IicStop();
//-----***-IIC应答-***-----//
void SendAcknowledge(bool ack)
    IicSdaDirOut;
      if(ack)//IicSda=ack;
          IicSdaHig;
    else
         IicSdaLow;
    Delay(TimeDelay);
    Delay(TimeDelay);
    Delay(TimeDelay);
//-----***-从slave端读取一个数据-***-----//
unsigned char IicReceiveByte(void)
    unsigned char i;
    unsigned char bytedata=0;
    IicSdaDirOut;
    IicSdaDirIn;
    for(i=0;i<8;i++)
        Delay(TimeDelay);
        bytedata<<=1;
        if(IicSdaInSt&BIT0)
              bytedata |=0x01;
        else
             bytedata &=0xfe;
        Delay(TimeDelay);
    IicSdaDirOut;
    return bytedata;
//-----***-传送一个 Byte 数据到 slave-***-----//
bool IicSentByte(unsigned char DataByte)
    unsigned char i;
    bool ack;
    ack=1;
    IicSdaDirOut;
    for(i=0;i<8;i++)
        if(DataByte & 0x80)
        else
        DataByte <<=1;
        Delay(TimeDelay);
        Delay(TimeDelay);
        Delay(TimeDelay);
    Delay(TimeDelay);
    Delay(TimeDelay);
    IicSdaDirIn;
    if(IicSdaInSt&BIT0)
            ack=0;
    else
            ack=1;
    IicSdaDirOut;
    Delay(TimeDelay);
    return ack;
//-----***-无扇区读---多字节-***-----//
//读取指定器件无扇区指定地址多字节数据到指定地址
//Device=器件地址---单字节
//DataAdd=字节地址---单字节
void IicMuchByteRead(unsigned char Device,unsigned char DataAdd,unsigned char *DataDptr,unsigned char DataLend)
    unsigned char i;
    IicWpHig;
    IicStart();
    IicSentByte(Device);
    IicSentByte(DataAdd);
    IicStart();
    IicSentByte(Device|0x01);
    for(i=0;i<DataLend-1;i++)
         *DataDptr=IicReceiveByte();
          DataDptr++;
          SendAcknowledge(0);
    SendAcknowledge(1);
    IicStop();
//-----***-无扇区写---多字节-***-----//
//写入指定器件无扇区指定地址中的多字节数据
//Device=器件地址---单字节
//DataAdd=字节地址---双字节
//DataByte=被存放数据的地址
//DataLend=被存放数据的长度
void IicMuchByteWrite(unsigned char Device,unsigned char DataAdd,unsigned char *DataDptr,unsigned char DataLend)
    unsigned char i,j;
    for(i=0;i<3;i++)
            AckErr=0;
            IicWpLow;
            IicStart();
            if(IicSentByte(Device)){IicErr();continue;}
            if(IicSentByte(DataAdd)){IicErr();continue;}
            for(j=0;j<DataLend;j++)
                    if(IicSentByte(*DataDptr)){IicErr();continue;}
                    DataDptr++;
            IicStop();
            if(!AckErr)
                    break;
    IicWpHig;
    Delay(50000);
 楼主| 雁舞白沙 发表于 2008-8-20 12:31 | 显示全部楼层
继续等待!
 楼主| 雁舞白沙 发表于 2008-8-20 13:41 | 显示全部楼层
再等!
 楼主| 雁舞白沙 发表于 2008-8-20 15:56 | 显示全部楼层
继续等待中!
emailli 发表于 2008-8-20 16:02 | 显示全部楼层
硬件,软件,电路======
硬件IO都一样?
都有上拉?
不通的CPU的指令时间都一样?
用的IIC芯片是否都是好的?
用示波器观察波形!电平是否正常?
用 逻辑分析仪抓数据,是否正常?
yewuyi 发表于 2008-8-20 17:17 | 显示全部楼层
检查一下IO口的方向设置
好象123和413在IO口附加功能上有所不同,如果在413上能用那估计IIC逻辑上没问题,应该是IO输出等硬件有问题。。。
没有示波器吗?用示波器看一下波形不就知道了吗?IIC可以单步一个CLOCK执行,用万用表应该都能量出来。。。。
古道热肠 发表于 2008-8-20 17:34 | 显示全部楼层
是通病吗?最好分清硬件故障还是软件故障
 楼主| 雁舞白沙 发表于 2008-8-21 08:42 | 显示全部楼层
可能是IO口可以正常输出,但不能输入!
