ccs3.3开发f28027时,程序编译通过,但是导入失败,用的是仿真器件。大家帮帮忙,我是菜鸟一个。
Error: Can't write to data memory 0x3F8800, check memory config [-2184]
cmd文件:
MEMORY
PAGE 0: /* Program Memory */
PRAMH0 : origin = 0x008000, length = 0x001000
PAGE 1: /* Data Memory */
RAMM0 : origin = 0x000000, length = 0x000400
RAMM1 : origin = 0x000400, length = 0x000400
DEV_EMU : origin = 0x000880, length = 0x000105 /* device emulation registers */
SYS_PWR_CTL : origin = 0x000985, length = 0x000003 /* System power control registers */
FLASH_REGS : origin = 0x000A80, length = 0x000060 /* FLASH registers */
CSM : origin = 0x000AE0, length = 0x000010 /* code security module registers */
ADC_RESULT : origin = 0x000B00, length = 0x000020 /* ADC Results register */
CPU_TIMER0 : origin = 0x000C00, length = 0x000008 /* CPU Timer0 registers */
CPU_TIMER1 : origin = 0x000C08, length = 0x000008 /* CPU Timer0 registers (CPU Timer1 & Timer2 reserved TI use)*/
CPU_TIMER2 : origin = 0x000C10, length = 0x000008 /* CPU Timer0 registers (CPU Timer1 & Timer2 reserved TI use)*/
PIE_CTRL : origin = 0x000CE0, length = 0x000020 /* PIE control registers */
PIE_VECT : origin = 0x000D00, length = 0x000100 /* PIE Vector Table */
COMP1 : origin = 0x006400, length = 0x000020 /* Comparator 1 registers */
COMP2 : origin = 0x006420, length = 0x000020 /* Comparator 2 registers */
EPWM1 : origin = 0x006800, length = 0x000040 /* Enhanced PWM 1 registers */
EPWM2 : origin = 0x006840, length = 0x000040 /* Enhanced PWM 2 registers */
EPWM3 : origin = 0x006880, length = 0x000040 /* Enhanced PWM 3 registers */
EPWM4 : origin = 0x0068C0, length = 0x000040 /* Enhanced PWM 4 registers */
ECAP1 : origin = 0x006A00, length = 0x000020 /* Enhanced Capture 1 registers */
GPIOCTRL : origin = 0x006F80, length = 0x000040 /* GPIO control registers */
GPIODAT : origin = 0x006FC0, length = 0x000020 /* GPIO data registers */
GPIOINT : origin = 0x006FE0, length = 0x000020 /* GPIO interrupt/LPM registers */
SYSTEM : origin = 0x007010, length = 0x000020 /* System control registers */
SPIA : origin = 0x007040, length = 0x000010 /* SPI-A registers */
SCIA : origin = 0x007050, length = 0x000010 /* SCI-A registers */
NMIINTRUPT : origin = 0x007060, length = 0x000010 /* NMI Watchdog Interrupt Registers */
XINTRUPT : origin = 0x007070, length = 0x000010 /* external interrupt registers */
ADC : origin = 0x007100, length = 0x000080 /* ADC registers */
I2CA : origin = 0x007900, length = 0x000040 /* I2C-A registers */
CSM_PWL : origin = 0x3F7FF8, length = 0x000008 /* Part of FLASHA. CSM password locations. */
PARTID : origin = 0x3D7FFF, length = 0x000001 /* Part ID register location */
DRAMH0 : origin = 0x3f8000, length = 0x001000
SECTIONS
.reset : > PRAMH0, PAGE = 0
.text : > PRAMH0, PAGE = 0
.cinit : > PRAMH0, PAGE = 0
/* Allocate data areas: */
.stack : > RAMM1, PAGE = 1
.bss : > DRAMH0, PAGE = 1
.ebss : > DRAMH0, PAGE = 1
.const : > DRAMH0, PAGE = 1
.econst : > DRAMH0, PAGE = 1
.sysmem : > DRAMH0, PAGE = 1
/*** PIE Vect Table and Boot ROM Variables Structures ***/
UNION run = PIE_VECT, PAGE = 1
PieVectTableFile
GROUP
EmuKeyVar
EmuBModeVar
FlashCallbackVar
FlashScalingVar
/*** Peripheral Frame 0 Register Structures ***/
DevEmuRegsFile : > DEV_EMU, PAGE = 1
SysPwrCtrlRegsFile: > SYS_PWR_CTL, PAGE = 1
FlashRegsFile : > FLASH_REGS, PAGE = 1
CsmRegsFile : > CSM, PAGE = 1
AdcResultFile : > ADC_RESULT, PAGE = 1
CpuTimer0RegsFile : > CPU_TIMER0, PAGE = 1
CpuTimer1RegsFile : > CPU_TIMER1, PAGE = 1
CpuTimer2RegsFile : > CPU_TIMER2, PAGE = 1
PieCtrlRegsFile : > PIE_CTRL, PAGE = 1
/*** Peripheral Frame 1 Register Structures ***/
ECap1RegsFile : > ECAP1 PAGE = 1
GpioCtrlRegsFile : > GPIOCTRL PAGE = 1
GpioDataRegsFile : > GPIODAT PAGE = 1
GpioIntRegsFile : > GPIOINT PAGE = 1
/*** Peripheral Frame 2 Register Structures ***/
SysCtrlRegsFile : > SYSTEM, PAGE = 1
SpiaRegsFile : > SPIA, PAGE = 1
SciaRegsFile : > SCIA, PAGE = 1
NmiIntruptRegsFile: > NMIINTRUPT, PAGE = 1
XIntruptRegsFile : > XINTRUPT, PAGE = 1
AdcRegsFile : > ADC, PAGE = 1
I2caRegsFile : > I2CA, PAGE = 1
/*** Peripheral Frame 3 Register Structures ***/
Comp1RegsFile : > COMP1, PAGE = 1
Comp2RegsFile : > COMP2, PAGE = 1
EPwm1RegsFile : > EPWM1 PAGE = 1
EPwm2RegsFile : > EPWM2 PAGE = 1
EPwm3RegsFile : > EPWM3 PAGE = 1
EPwm4RegsFile : > EPWM4 PAGE = 1
/*** Code Security Module Register Structures ***/
CsmPwlFile : > CSM_PWL, PAGE = 1
/*** Device Part ID Register Structures ***/
PartIdRegsFile : > PARTID, PAGE = 1
