STM32 FSMC K9k2g08u0m 读写不一样
1977|0
 楼主| iamyj2007 发表于 2013-1-19 23:27 | 显示全部楼层 |阅读模式
读写函数如下
u32 FSMC_NAND_WriteSmallPage(u8 *pBuffer, NAND_ADDRESS Address, u32 NumPageToWrite)
  u32 index = 0x00, numpagewritten = 0x00, addressstatus = NAND_VALID_ADDRESS;
  u32 status = NAND_READY, size = 0x00;
  while((NumPageToWrite != 0x00) && (addressstatus == NAND_VALID_ADDRESS) && (status == NAND_READY))
    /* Page write command and address */
    *(vu8 *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_PAGEPROGRAM;
    *(vu8 *)(Bank_NAND_ADDR | ADDR_AREA) = 0x00;
    *(vu8 *)(Bank_NAND_ADDR | ADDR_AREA) = 0X00;
    *(vu8 *)(Bank_NAND_ADDR | ADDR_AREA) = ADDR_1st_CYCLE(ROW_ADDRESS);
    *(vu8 *)(Bank_NAND_ADDR | ADDR_AREA) = ADDR_2nd_CYCLE(ROW_ADDRESS);
        *(vu8 *)(Bank_NAND_ADDR | ADDR_AREA) = ADDR_3rd_CYCLE(ROW_ADDRESS);
    /* Calculate the size */
    size = NAND_PAGE_SIZE + (NAND_PAGE_SIZE * numpagewritten);
    /* Write data */
    for(; index < size; index++)
      *(vu8 *)(Bank_NAND_ADDR | DATA_AREA) = pBuffer[index];
    *(vu8 *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_PAGEPROGRAM_TRUE;
   // while( GPIO_ReadInputDataBit(GPIOD, GPIO_Pin_6) == 0 );
    /* Check status for successful operation */
    status = FSMC_NAND_GetStatus();
    if(status == NAND_READY)
      numpagewritten++;
      NumPageToWrite--;
      /* Calculate Next small page Address */
      addressstatus = FSMC_NAND_AddressIncrement(&Address);
  return (status | addressstatus);
u32 FSMC_NAND_ReadSmallPage(u8 *pBuffer, NAND_ADDRESS Address, u32 NumPageToRead)
  u32 index = 0x00, numpageread = 0x00, addressstatus = NAND_VALID_ADDRESS;
  while((NumPageToRead != 0x0) && (addressstatus == NAND_VALID_ADDRESS))
    /* Page Read command and page address */
    *(vu8 *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_READ_1;
    *(vu8 *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_READ_TRUE;
    //while( GPIO_ReadInputDataBit(GPIOD, GPIO_Pin_6) == 0 );
    size = NAND_PAGE_SIZE + (NAND_PAGE_SIZE * numpageread);
    /* Get Data into Buffer */
      pBuffer[index]= *(vu8 *)(Bank_NAND_ADDR | DATA_AREA);
    numpageread++;
    NumPageToRead--;
    /* Calculate page address */
连续递增填充pBuffer函数:
void Fill_Buffer(u8 *pBuffer, u16 BufferLenght, u32 Offset)
  u16 IndexTmp = 0;
  for (IndexTmp = 0; IndexTmp < BufferLenght; IndexTmp++ )
    pBuffer[IndexTmp] =IndexTmp+Offset ;
这样可以读写成功
但是当我修改连续填充函数后读写不成功,如:
  u16 IndexTmp = 0;
    pBuffer[IndexTmp] =2+Offset ;
现在输入都是2后读写不成功
