我在网上或有些工程里看到,例如下面写法的启动代码,我想问这是在keil下跑的启动代码吗?我这确实有个keil工程里面是这么写的。但是是代码里用//或/* */ C语言的语法进行注解,而且里面有些语法和我现在创建工程里自带的启动代码不同,例如现在是以;来注解。请问这是为什么?
拜求大神解答!!!:'(
// Starupt Code must be linked first at Address at which it expects to run.
$IF (EXTERNAL_MODE)
CODE_BASE EQU 0x80000000
$ELSE
CODE_BASE EQU 0x00000000
$ENDIF
AREA STARTUPCODE, CODE, AT CODE_BASE // READONLY, ALIGN=4
PUBLIC __startup
EXTERN CODE32 (?C?INIT)
__startup PROC CODE32
// Pre-defined interrupt handlers that may be directly
// overwritten by C interrupt functions
EXTERN CODE32 (Undef_Handler?A)
EXTERN CODE32 (SWI_Handler?A)
EXTERN CODE32 (PAbt_Handler?A)
EXTERN CODE32 (DAbt_Handler?A)
EXTERN CODE32 (IRQ_Handler?A)
EXTERN CODE32 (FIQ_Handler?A)
// Exception Vectors
// Mapped to Address 0.
// Absolute addressing mode must be used.
