isd 在stc下载板上的测试代码
2435|0
 楼主| chuandaoxy 发表于 2008-2-26 09:34 | 显示全部楼层 |阅读模式
代码来自俄罗斯的网站,我改动过
isd还有一些不太明白的问题,大家讨论一下
单步执行到ISDwait (); 老是跳不出去  ,那位用过介绍一下经验
TEST.C:  ISD51 Demo for classic 8051 devices like Philips 89C51RD2/89C66x
Copyright 2002 Keil Software, Inc.
Modified by Alexey Selischev, Aug., 2002
#include <reg52.h>               //stc89C516RD+(P89C51RD**)ISD连接pass
#include <intrins.h>             //stc89LE58RD+(WE78LE58)  ISD连接pass
#include <absacc.h>
#include "ISD51.h"
sbit P15 = P1^0;
sbit P16 = P1^1;
sbit P17 = P1^2;
#define LEDS    XBYTE [0xFFFF]   // 0 - on, 1 - off
void delay(void)
  unsigned int i;
  i = 0x800;
  while(i--);
void main (void)
    unsigned int j;
    unsigned char ext_reg = 0;
    SCON = 0x50;
    //PCON &= 0x7F;
   T2CON &= 0xF0;               /* EXEN2=0; TR2=0; C/T2#=0; CP/RL2#=0; */
   T2CON |= 0x30;               /* RCLK = 1; TCLK=1; */
   RCAP2H=0xFF;                 /* reload value, 9600 Bds at 18.432MHz */
   RCAP2L=0xC4;                 /* reload value, 9600 Bds at 18.432MHz */
   ES = 1;                         /* Enable serial interrupt */
   EA = 1;                        /* Enable global interrupt */
   TR2 = 1;                     /* Timer 2 run */
//    TMOD = 0x20;
//    TH1 = 0xfd;
//    TR1 = 1;
    REN = 1;
    EA = 1;
    ISDinit ();        // initialize uVision2 Debugger and continue program run
    ISDwait ();        // wait for connection to uVision2 Debugger
    P17 = 0; P16 = 0; P15 = 0; //耜铐翳泱痂痤忄螯 P15..P17 赅?鲨麴钼铋 怩钿
    while (1)
                     // init ISD51 only when the uVision2 Debugger tries to connect
    ISDcheck();      // initialize uVision2 Debugger and continue program run
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    ext_reg = (char) P15;
    ext_reg = ext_reg << 1;
    ext_reg = ext_reg + (char) P16;
    LEDS = ext_reg;
    j++;
    if (P17 == 0)
        ext_reg = 0;
        j = 0;
        // you may use ISDbreak when ISD51 is started with ISDcheck or ISDwait
        //    ISDbreak ();  // hard coded stop (breakpoint)
    _nop_();
    _nop_();
    _nop_();
    delay();
    _nop_();
    _nop_();
    _nop_();
