- #include"sn8p_init_sys.h"
- void init_sys(void);
- unsigned char i,j;
- beep_lock = false;
- BEEPM = 1;
- seg1_m = 1;
- seg2_m= 1;
- seg3_m =1;
- seg4_m =1;
- seg5_m =1;
- Mode.OptMode = 0x00;
- Mode.Number = 0x03;//上电先跑第三
- FP54M=1;
- TC0M = 0x54; //TC0M register value, Fcpu: 4.000000MHZ//CLK source: Fcpu
- TC0C = 0x4C; //TC0C register value, time: 360.000000us(2777.777778HZ)
- TC0R = 0x4C; //TC0R register value
- FTC0IRQ = 0;
- FTC0IEN = 1; //TC0 Interrupt enable
- FTC0ENB = 1; //TC0 enable
- T0M = 0x70; //T0M register value, Fcpu: 4.000000MHZ//CLK source: Fcpu
- T0C = 0x9C; //T0C register value, time: 50.000000us
- FT0IRQ = 0;
- FT0IEN = 1; //T0 Interrupt enable
- FT0ENB = 1; //T0 enable
- FGIE= 1;
- #include"sn8p_bias_lcd_driver.h"
- //定义22幅画面
- __ROM unsigned char
- //SetMode
- seg_code_1[4] = {0x40,0x20,0x68,0x20},//flash_1
- seg_code_2[4] = {0x80,0xE0,0x60,0xA8},//flash_2
- seg_code_3[4] = {0xC0,0x60,0x60,0x60},//flash_3
- seg_code_4[4] = {0x00,0x20,0x20,0x20},//flash_none 0000 0000,0010 0000,0010 0000,0010 0000
- //RunMode
- seg_code_1r[28] =
- 0x40,0x20,0x68,0x20,
- 0x40,0x28,0x68,0x20,
- 0x48,0x28,0x68,0x20,
- 0x58,0x28,0x68,0x20,
- 0x58,0x38,0x68,0x20,
- 0x58,0x38,0x78,0x20,
- 0x58,0x38,0x78,0x30,
- seg_code_2r[28] =
- 0x80,0xE0,0x60,0xA8,
- 0x80,0xE8,0x60,0xA8,
- 0x88,0xE8,0x60,0xA8,
- 0x98,0xE8,0x60,0xA8,
- 0x98,0xF8,0x60,0xA8,
- 0x98,0xF8,0x70,0xA8,
- 0x98,0xF8,0x70,0xB8,
- seg_code_3r[28] =
- 0xC0,0x60,0x60,0xE0,
- 0xC0,0x68,0x60,0xE0,
- 0xC8,0x68,0x60,0xE0,
- 0xD8,0x68,0x60,0xE0,
- 0xD8,0x78,0x60,0xE0,
- 0xD8,0x78,0x70,0xE0,
- 0xD8,0x78,0x70,0xF0,
- void dispp(unsigned char *pCode);
- static void select_seg(unsigned char seg_x);
- seg1 =(seg_x&0x80)>0x00?1:0;
- seg2 =(seg_x&0x40)>0x00?1:0;
- seg3 =(seg_x&0x20)>0x00?1:0;
- seg4 =(seg_x&0x10)>0x00?1:0;
- seg5 =(seg_x&0x08)>0x00?1:0;
- static unsigned char ScanCount=0;
- switch(ScanCount) //动态扫描显示
- case 0: //com1正向驱动
- select_seg(*pCode);
- com1 = 0;
- com1_m = 1;
- com2_m = 0;
- com3_m = 0;
- com4_m = 0; //除com1输出外,其余com设为输入
- break;
- case 1: //com1反向驱动
- select_seg(~*pCode);
- com1 = 1;
- break;
- case 2: //com2正向驱动
- select_seg(*(pCode+1));
- com2 = 0;
- com1_m = 0;
- com2_m = 1;
- com3_m = 0;
- com4_m = 0;
- break;
- case 3: //com2反向驱动
- select_seg(~*(pCode+1));
- com2 = 1;
- break;
- case 4: //com3正向驱动
- select_seg(*(pCode+2));
- com3 = 0;
- com1_m = 0;
- com2_m = 0;
- com3_m = 1;
- com4_m = 0;
- break;
- case 5: //com3反向驱动
- select_seg(~*(pCode+2));
- com3 = 1;
- break;
- case 6: //com4正向驱动
- select_seg(*(pCode+3));
- com4 = 0;
- com1_m = 0;
- com2_m = 0;
- com3_m = 0;
- com4_m = 1;
- break;
- case 7: //com4反向驱动
- select_seg(~*(pCode+3));//1111 1111
- com4 = 1;
- com1_m = 0;
- com2_m = 0;
- com3_m = 0;
- com4_m = 1;
- break;
- default:
- break;
- ScanCount++;
- if(ScanCount>=8)
- ScanCount=0;
