STM32F103的EP1,EP2,EP3只有一个能正常工作的问题
3163|1
 楼主| sdwuyawen 发表于 2013-5-1 22:32 | 显示全部楼层 |阅读模式
基于ST官方的JoyStickMouse修改的程序,原程序是用EP1发送4个字节数据,我想把它改成使用EP2或者发送EP3发送。
但是发现:
usb_desc.h:把JOYSTICK_SIZ_CONFIG_DESC改成48,即34+7+7
usb_desc.c:
const uint8_t Joystick_ConfigDescriptor[JOYSTICK_SIZ_CONFIG_DESC] =
    0x09, /* bLength: Configuration Descriptor size */
    USB_CONFIGURATION_DESCRIPTOR_TYPE, /* bDescriptorType: Configuration */
    JOYSTICK_SIZ_CONFIG_DESC,
    /* wTotalLength: Bytes returned */
    0x00,
    0x01,         /*bNumInterfaces: 1 interface*/
    0x01,         /*bConfigurationValue: Configuration value*/
    0x00,         /*iConfiguration: Index of string descriptor describing
                                     the configuration*/
    0xE0,         /*bmAttributes: bus powered */
    0x32,         /*MaxPower 100 mA: this current is used for detecting Vbus*/
    /************** Descriptor of Joystick Mouse interface ****************/
    /* 09 */
    0x09,         /*bLength: Interface Descriptor size*/
    USB_INTERFACE_DESCRIPTOR_TYPE,/*bDescriptorType: Interface descriptor type*/
    0x00,         /*bInterfaceNumber: Number of Interface*/
    0x00,         /*bAlternateSetting: Alternate setting*/
    0x03,         /*bNumEndpoints*/
    0x03,         /*bInterfaceClass: HID*/
    0x01,         /*bInterfaceSubClass : 1=BOOT, 0=no boot*/
    0x02,         /*nInterfaceProtocol : 0=none, 1=keyboard, 2=mouse*/
    0,            /*iInterface: Index of string descriptor*/
    /******************** Descriptor of Joystick Mouse HID ********************/
    /* 18 */
    0x09,         /*bLength: HID Descriptor size*/
    HID_DESCRIPTOR_TYPE, /*bDescriptorType: HID*/
    0x00,         /*bcdHID: HID Class Spec release number*/
    0x01,
    0x00,         /*bCountryCode: Hardware target country*/
    0x01,         /*bNumDescriptors: Number of HID class descriptors to follow*/
    0x22,         /*bDescriptorType*/
    JOYSTICK_SIZ_REPORT_DESC,/*wItemLength: Total length of Report descriptor*/
    0x00,
    /******************** Descriptor of Joystick Mouse endpoint ********************/
    /* 27 */
  0x07,          /*bLength: Endpoint Descriptor size*/
    USB_ENDPOINT_DESCRIPTOR_TYPE, /*bDescriptorType:*/
    0x83,          /*bEndpointAddress: Endpoint Address (IN)*/
    0x03,          /*bmAttributes: Interrupt endpoint*/
    0x04,          /*wMaxPacketSize: 4 Byte max */
    0x00,
    0x20,          /*bInterval: Polling Interval (32 ms)*/
    /* 34 */
    0x82,          /*bEndpointAddress: Endpoint Address (IN)*/
    0x00,
  /*41*/
    0x81,          /*bEndpointAddress: Endpoint Address (IN)*/
    0x00,
  /*48*/
usb_conf.h中:
把#define EP_NUM     (2)  改成  #define EP_NUM     (4)
#define ENDP0_RXADDR        (0x50)
#define ENDP0_TXADDR        (0x90)
#define ENDP1_TXADDR        (0xC0)
#define ENDP1_RXADDR        (0xD0)
#define ENDP2_TXADDR        (0x100)
#define ENDP2_RXADDR        (0x140)
#define ENDP3_TXADDR        (0x180)
#define ENDP3_RXADDR        (0x1C0)
hw_config.c中:
  USB_SIL_Write(EP3_IN, Mouse_Buffer, 4);
  SetEPTxValid(ENDP3);
这样,端点3可以正常IN。但是,如果我把hw_config.c中的EP3换成EP2或EP1,则工作不正常。
而且,如果交换usb_desc.c中三个端点描述的顺序,则总是第一个被描述的端点能正常IN,而其他两个都不行。
这是什么原因呢?
 楼主| sdwuyawen 发表于 2013-5-3 23:23 | 显示全部楼层
我现在的理解是,一个Interface不能有多个IN端点,否则只有在端点描述符位置靠前的IN端点能使用。求指导啊!
