#include <reg52.h>
#include <stdio.h>
#define uchar unsigned char
#define uint unsigned int
uchar code table1[]="wenduceliang";
char table[10];
sbit ds=P2^2;
sbit lcden=P3^4;
sbit lcdrs=P3^5;
uint temp;
float f_temp;
void delayms(uint z)//延时ms函数
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void dsreset(void) //de18b20初始化函数
uint i;
ds=0;
i=103;
while(i>0)
i--;
ds=1;
i=4;
while(i>0)
i--;
bit tempreadbit(void) //读一位数据函数
uint i;
bit dat;
ds=0;
i++;
ds=1;
i++;i++;
dat=ds;
i=8;
while(i>0)i--;
return(dat);
uchar tempread(void) //读一个字节的数据函数
uchar i,j,dat;
dat=0;
for(i=1;i<=8;i++)
j=tempreadbit();
dat=(j<<7)|(dat>>1);
return(dat);
void tempwritebyte(uchar dat) //向ds18b20写一个字节
uint i;uchar j;
bit testb;
for(j=1;j<=8;j++)
testb=dat&0x01;
dat=dat>>1;
if(testb)
ds=0;
i++;i++;
ds=1;
i=8;
while(i>0)i--;
else
ds=0;
i=8;while(i>0)i--;
ds=1;
i++;i++;
void tempchange(void) //ds18b20开始获取温度并开始转换
dsreset();
delayms(1);
tempwritebyte(0xcc);
tempwritebyte(0x44);
uint get_temp() //读取寄存器中存储的温度数据
uchar a,b;
dsreset();
delayms(1);
tempwritebyte(0xbe);
a=tempread();
b=tempread();
temp=b;
temp<<=8;
temp=temp|a;
f_temp=temp*0.0625;
temp=f_temp*10+0.5;
f_temp=f_temp+0.05;
return temp;
void lcdwrite_com(uchar com)
lcdrs=0;
P0=com;
delayms(5);
lcden=1;
delayms(5);
lcden=0;
void lcdwrite_data(uchar date)
lcdrs=1;
P0=date;
delayms(5);
lcden=1;
delayms(5);
lcden=0;
void lcdinit()
lcden=0;
lcdwrite_com(0x38);
lcdwrite_com(0x0c);
lcdwrite_com(0x06);
lcdwrite_com(0x01);
void lcddisplay()
uchar num;
lcdinit();
lcdwrite_com(0x80);
for(num=0;num<12;num++)
lcdwrite_data(table1[num]);
delayms(5);
lcdwrite_com(0x80+0x40);
for(num=0;num<=10;num++)
lcdwrite_data(table[num]);
delayms(5);
while(1);
void main()
tempchange();
delayms(500);
get_temp();
sprintf(table,"%f",f_temp);
lcddisplay();
