stm32 两通道采集片内温度和电压 问题出在哪?
1972|5
 楼主| 奕明丶 发表于 2013-5-22 16:13 | 显示全部楼层 |阅读模式
输出完全不符合实际!!!!
void DMA_Configuration(void)
{   /* DMA1 channel1 configuration ----------------------------------------------*/
  DMA_DeInit(DMA1_Channel1);                 //DMAµÄ11ͨµÀ
  DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;         //DMA¶ÔÓ¦µÄÍâÉè»ùµØÖ·
  DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&AD_value; //Êý¾Ý´æ´¢µØÖ·
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;                          //ÍâÉè×÷ΪÊý¾Ý´«ÊäµÄÀ´Ô´
  DMA_InitStructure.DMA_BufferSize =2;                                                          //»º´æ´óС
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;                 //ÍâÉèµØÖ·¼Ä´æÆ÷²»±ä
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;                           //ÄÚ´æµØÖ·¼Ä´æÆ÷²»±ä          ¶àͨµÀʹÄÜ£¿£¿
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;         //ÍâÉèÊý¾Ý¿í¶È16λ
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;                        //16λ
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;           //Ñ­»·»º´æÄ£Ê½
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;  //¸ßÓÅÏȼ¶
  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;                   //ͨµÀxûÓÐÉèÖõ½ÄÚ´æµ½ÄÚ´æ´«Êä
  DMA_Init(DMA1_Channel1, &DMA_InitStructure);
          DMA_Cmd(DMA1_Channel1, ENABLE);
void ADC_Configuration(void)
/* ADC1 configuration ------------------------------------------------------*/
  ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;                //¶ÀÁ¢Ä£Ê½
  ADC_InitStructure.ADC_ScanConvMode = ENABLE;
  ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;                //ʹÄÜÁ¬Ðø×ª»»Ä£Ê½
  ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;        //ADCÍⲿ´¥·¢¹Ø±Õ
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;         //Êý¾ÝÓÒ¶ÔÆë
  ADC_InitStructure.ADC_NbrOfChannel = 2;         //¿ªÆôͨµÀÊý 1
// ADC_InitStructure.ADC_NbrOfChannel = 1;
  ADC_Init(ADC1, &ADC_InitStructure);
  ADC_TempSensorVrefintCmd(ENABLE); //ʹÄÜζȴ«¸ÐÆ÷ºÍÄÚ²¿²Î¿¼µçѹͨµÀ
  /* ADC1 regular channel13 configuration */
  ADC_RegularChannelConfig(ADC1, ADC_Channel_13, 1, ADC_SampleTime_55Cycles5);           //28.5ms ²ÉÑùʱ¼ä
  ADC_RegularChannelConfig(ADC1, ADC_Channel_16, 2, ADC_SampleTime_239Cycles5);
  /* Enable ADC1 DMA */
  ADC_DMACmd(ADC1, ENABLE);
  /* Enable ADC1 */
  ADC_Cmd(ADC1, ENABLE);
  /* Enable ADC1 reset calibaration register */
  ADC_ResetCalibration(ADC1);
  /* Check the end of ADC1 reset calibration register */
  while(ADC_GetResetCalibrationStatus(ADC1));
  /* Start ADC1 calibaration */
  ADC_StartCalibration(ADC1);
  /* Check the end of ADC1 calibration */
  while(ADC_GetCalibrationStatus(ADC1));
主函数部分
ADC_SoftwareStartConvCmd(ADC1, ENABLE);
while (1)
//                   while(USART_GetFlagStatus(USART1,USART_FLAG_TXE)==RESET);//µÈ´ý´«ÊäÍê³É·ñÔòµÚһλÊý¾ÝÈÝÒ×¶ªÊ§
          /* Set Clock1s to 1 every 1 second    */
                if (ticks++ >= 900000)
                            ticks   = 0;
                    Clock1s = 1;
                  /* Printf message with AD value to serial port every 1 second  */
          if (Clock1s)
                     Clock1s = 0;
                         //        AD_value[0] = (unsigned int)(((unsigned int)AD_value[0])*3300>>12);   /* °Ñ²É¼¯µ½µÄÊýֵת»»³ÉµçѹÊý¾Ý */
                                   AD_value[0] = AD_value[0]*3300/4096         ;
                                AD_value[1]=(1.43-AD_value[1]*3.3/4096)*1000/4.35 + 25;
                        HexToASCII(AD_value[0]);
                        USART1Write((uint8_t*)AsciiBuff,4);
                        USART1Write((uint8_t*)"\r\n",sizeof("\r\n"));
                 HexToASCII(AD_value[1]);
 楼主| 奕明丶 发表于 2013-5-22 16:19 | 显示全部楼层
单通道单独测试的时候都是正确的
温度
温度
电压
电压
IJK 发表于 2013-5-22 16:55 | 显示全部楼层
都用 ADC_SampleTime_239Cycles5 试试
 楼主| 奕明丶 发表于 2013-5-22 18:01 | 显示全部楼层
已解决 AD_value[1]转换一行调到HexToASCII(AD_value[1]); 就行了
实际效果
实际效果
实际效果
实际效果
 楼主| 奕明丶 发表于 2013-5-22 18:02 | 显示全部楼层
AD_value[1]=(1.43-AD_value[1]*3.3/4096)*1000/4.35 + 25;   这一行调一下位置就好了  不知道什么原因
cjhk 发表于 2013-5-22 19:03 | 显示全部楼层
不是很了解   楼主   帮你顶一个   看看别人的意见   这个真的没能力解决
