编译出问题?lib文件中。。怎么么会将lib文件认为非法呢?
4172|2
 楼主| lcgolh 发表于 2013-6-1 10:50 | 显示全部楼层 |阅读模式
爆出的错误如下:类
"F:/softrest/ccs/lesson1/lesson1/INCLUDE/rts2800_ml.lib", line 3: error #7: unrecognized token
gmake: *** [source/DSP2833x_MemCopy.obj] Error 1
'Building file: ../source/DSP2833x_PieCtrl.c'
'Invoking: C2000 Compiler'
"D:/soft ware/CCS/ccsv5/tools/compiler/c2000/bin/cl2000" -v28 -ml -mt --float_support=fpu32 -g --preinclude="F:/softrest/ccs/lesson1/lesson1/INCLUDE/IQmathLib.h" --preinclude="F:/softrest/ccs/lesson1/lesson1/INCLUDE/rts2800_ml.lib" --include_path="D:/soft ware/CCS/ccsv5/tools/compiler/c2000/include" --diag_warning=225 --display_error_number --preproc_with_compile --preproc_dependency="source/DSP2833x_PieCtrl.pp" --obj_directory="source"  "../source/DSP2833x_PieCtrl.c"
"F:/softrest/ccs/lesson1/lesson1/INCLUDE/rts2800_ml.lib", line 1: error #171: expected a declaration
"F:/softrest/ccs/lesson1/lesson1/INCLUDE/rts2800_ml.lib", line 2: error #7: unrecognized token
"F:/softrest/ccs/lesson1/lesson1/INCLUDE/rts2800_ml.lib", line 3: error #915: invalid character in input line
.lib文件不能改,是CCs5 的那个地方需要设置吗?还是其他文件包含的问题呢?  请前辈指点?。。。
zhangmangui 发表于 2013-6-1 17:15 | 显示全部楼层
rts2800_ml.lib有问题  这是在ccs 设置软件里面选择cpu后自动添加的
 楼主| lcgolh 发表于 2013-6-2 07:55 | 显示全部楼层
自己就不用另外添加了!!?谢谢呵呵:D
