u-boot 第一阶段代码求解
1749|1
 楼主| jy02326166 发表于 2013-6-4 22:18 | 显示全部楼层 |阅读模式
.macro get_bad_stack
        ldr        r13, _armboot_start                @ setup our mode stack
        sub        r13, r13, #(CONFIG_STACKSIZE+CFG_MALLOC_LEN)
        sub        r13, r13, #(CFG_GBL_DATA_SIZE+8) @ reserved a couple spots in abort stack
        str        lr, [r13]                        @ save caller lr / spsr
        mrs        lr, spsr            @ spsr to lr
        str lr, [r13, #4]
        mov        r13, #MODE_SVC                @ prepare SVC-Mode   MODE_SVC = 0x13
        @ msr        spsr_c, r13
        msr        spsr, r13           @ r13 to spsr
        mov        lr, pc
        movs        pc, lr
        .endm
.macro        bad_save_user_regs
        sub        sp, sp, #S_FRAME_SIZE
        stmia        sp, {r0 - r12}                        @ Calling r0-r12
        ldr        r2, _armboot_start
        sub        r2, r2, #(CONFIG_STACKSIZE+CFG_MALLOC_LEN)
        sub        r2, r2, #(CFG_GBL_DATA_SIZE+8)  @ set base 2 words into abort stack
        ldmia        r2, {r2 - r3}                        @ get pc, cpsr
        add        r0, sp, #S_FRAME_SIZE                @ restore sp_SVC
        add        r5, sp, #S_SP
        mov        r1, lr
        stmia        r5, {r0 - r3}                        @ save sp_SVC, lr_SVC, pc, cpsr
        mov        r0, sp
        .endm
异常时这样顺序执行,红色部分的sp值时多少,我一直没弄清楚.如果sp是R13的话那不就是MODE_SVC = 0x13吗?显然不对啊~
Xplain 发表于 2013-6-8 22:13 | 显示全部楼层
每个模式的SP值是一上电就设好了的,异常时进到这里的时候SP值就是刚上电的时候设置的值,如果上电的时候没设,那就是0咯,像uboot一般不用中断,MODE_IRQ的SP不设置也没关系
