39R16A3内部ADC驱动代码
2601|0
 楼主| FOSVOSSH 发表于 2013-6-15 21:39 | 显示全部楼层 |阅读模式
// SyncMos/On-Bright MCU
// FOSVOS.cn
// 021-58998693
// Driver file for SM39R16A3/OB39R16A3, SM39R08A3/OB39R08A3
#include "SM39R16A3.h"
#include "ADC.h"
#define d_ADCnEN                 0x02
#define d_ADC_CLK_Sel        d_ADC_CLK_DIV64
unsigned int n_data;
void ADCstart(unsigned char n_ADC_CH)
        ADCC2 &= 0x7F;                //ADC stop conversion
        ADCC2 = n_ADC_CH;        //Set a new channel
        ADCC2 |= 0x80;                //ADC start conversion
void ADCInit(unsigned char n_ADCnEN, unsigned char n_ADC_CLK)
        ADCC1 = n_ADCnEN;        //Set ADC channel
        ADCCS = n_ADC_CLK;        //Select ADC clock
        IEADC = 1;                        //Enable ADC interrupt.
        EA = 1;
unsigned int ADC_Read10()//10-bit ADC
        unsigned int n_ADCD10 = 0x0000;
        n_ADCD10 = (ADCDH<<2)|ADCDL;        //10-bit ADC
        return n_ADCD10;
void ADCInterrupt(void) interrupt d_ADC_Vector        // ADC Interrupt Vector Address 0053h => interrupt 10
        n_data = ADC_Read10();        //Read ADC
void ADC_stop(void)
        IEADC = 0;                //Disable ADC interrupt
void ADC(void)
        if (d_ADCnEN & 0x01)
                ADCstart(d_ADC_CH0_IN);
                while(!ADCIF);
        if (d_ADCnEN & 0x02)
                ADCstart(d_ADC_CH1_IN);
                while(!ADCIF);
        if (d_ADCnEN & 0x04)
                ADCstart(d_ADC_CH2_IN);
                while(!ADCIF);
        if (d_ADCnEN & 0x08)
                ADCstart(d_ADC_CH3_IN);
                while(!ADCIF);
        if (d_ADCnEN & 0x10)
                ADCstart(d_ADC_CH4_IN);
                while(!ADCIF);
        if (d_ADCnEN & 0x20)
                ADCstart(d_ADC_CH5_IN);
                while(!ADCIF);
        if (d_ADCnEN & 0x40)
                ADCstart(d_ADC_CH6_IN);
                while(!ADCIF);
        if (d_ADCnEN & 0x80)
                ADCstart(d_ADC_CH7_IN);
                while(!ADCIF);
