我的行为级仿真能通过,但在MODELSIM里面提示了如下错误: Loading work.Rxcrctest_v<br /># ** Error: (vsim-19) Failed to access library 'xilinxcorelib_ver' at "xilinxcorelib_ver".<br /># No such file or directory. (errno = ENOENT)<br /># ** Error: (vsim-19) Failed to access library 'unisims_ver' at "unisims_ver".<br /># No such file or directory. (errno = ENOENT)<br /># Loading work.Rx_CRC<br /># ** Error: (vsim-19) Failed to access library 'xilinxcorelib_ver' at "xilinxcorelib_ver".<br /># No such file or directory. (errno = ENOENT)<br /># ** Error: (vsim-19) Failed to access library 'unisims_ver' at "unisims_ver".<br /># No such file or directory. (errno = ENOENT)<br /># Loading work.recv<br /># ** Error: (vsim-19) Failed to access library 'xilinxcorelib_ver' at "xilinxcorelib_ver".<br /># No such file or directory. (errno = ENOENT)<br /># ** Error: (vsim-19) Failed to access library 'unisims_ver' at "unisims_ver".<br /># No such file or directory. (errno = ENOENT)<br /># Loading work.CRC_chk<br /># ** Warning: (vsim-3009) [TSCALE] - Module 'CRC_chk' does not have a `timescale directive in effect, but previous modules do.<br /># Region: /Rxcrctest_v/uut/My_crcchk<br /># ** Error: (vsim-19) Failed to access library 'xilinxcorelib_ver' at "xilinxcorelib_ver".<br /># No such file or directory. (errno = ENOENT)<br /># ** Error: (vsim-19) Failed to access library 'unisims_ver' at "unisims_ver".<br /># No such file or directory. (errno = ENOENT)<br /># Loading work.clk_Div<br /># ** Error: (vsim-19) Failed to access library 'xilinxcorelib_ver' at "xilinxcorelib_ver".<br /># No such file or directory. (errno = ENOENT)<br /># ** Error: (vsim-19) Failed to access library 'unisims_ver' at "unisims_ver".<br /># No such file or directory. (errno = ENOENT)<br /># Loading work.clk_DataReady<br /># Loading work.glbl<br /><br /><br />但是综合后仿真就不行了,提示错误如下:# ** Error: (vsim-19) Failed to access library 'simprims_ver' at "simprims_ver".<br /># No such file or directory. (errno = ENOENT)<br /># Loading work.Rx_CRC<br /># ** Error: (vsim-19) Failed to access library 'simprims_ver' at "simprims_ver".<br /># No such file or directory. (errno = ENOENT)<br /># ** Error: (vsim-3033) Rx_CRC_translate.v(257): Instantiation of 'X_FF' failed. The design unit was not found.<br /># Region: /Rxcrctest_v/uut<br /># Searched libraries:<br /># ** Error: (vsim-19) Failed to access library 'simprims_ver' at "simprims_ver".<br /># No such file or directory. (errno = ENOENT)<br /># work<br /># ** Error: (vsim-19) Failed to access library 'simprims_ver' at "simprims_ver".<br /># No such file or directory. (errno = ENOENT)<br /># ** Error: (vsim-3033) Rx_CRC_translate.v(266): Instantiation of 'X_FF' failed. The design unit was not found.<br /># Region: /Rxcrctest_v/uut<br /># Searched libraries:<br /># ** Error: (vsim-19) Failed to access library 'simprims_ver' at "simprims_ver".<br /># No such file or directory. (errno = ENOENT)<br /># work<br /># ** Error: (vsim-19) Failed to access library 'simprims_ver' at "simprims_ver".<br /><br />………………<br />后面还有很多,波形出不来。<br /><br />请问是仿真器设置的问题还是程序的问题呢?我的程序综合的时候连警告都没有。谢谢~<br /> |
