[51单片机] 字节写入eeprom问题,假设写入abcd的话,读出的是cdcd。。。为什么
1889|2
 楼主| 飞鸟yl 发表于 2013-11-16 14:20 | 显示全部楼层 |阅读模式
#include<reg52.h>
#include<intrins.h>
#define        uchar        unsigned char
#define        uint        unsigned int
sfr                ISP_DATA=0xe2;
sfr         ISP_ADDRH=0xe3;
sfr         ISP_ADDRL=0xe4;
sfr         ISP_CMD=0xe5;
sfr         ISP_TRIG=0xe6;
sfr         ISP_CONTR=0xe7;
uchar k;
void iap_disable()                                //防止误触发;
        ISP_CONTR=0x00;
        ISP_CMD=0x00;
        ISP_TRIG=0x00;
uchar byte_read(uchar add)                                //读字节;
        ISP_CONTR=0x81;
        ISP_CMD=0x01;
        ISP_ADDRH=0x28;
        ISP_ADDRL=add;
        EA=0;
        ISP_TRIG=0x46;
        ISP_TRIG=0xb9;
        _nop_();
        k=ISP_DATA;
        EA=1;
        iap_disable();
        return(k);
void byte_program(uchar add,uchar num)                                 //写字节;
        ISP_CONTR=0x81;
        ISP_CMD=0x02;
        ISP_ADDRH=0x28;
        ISP_ADDRL=add;
        ISP_DATA=num;
        EA=0;
        ISP_TRIG=0x46;
        ISP_TRIG=0xb9;
        EA=1;
        iap_disable();
void sector_erase()                                 //檫除扇区;
        ISP_CONTR=0x81;
        ISP_CMD=0x03;
        ISP_ADDRH=0x28;
        ISP_ADDRL=0x00;
        EA=0;
        ISP_TRIG=0x46;
        ISP_TRIG=0xb9;
        _nop_();
        EA=1;
        iap_disable();
void main()
        uchar a=0,b=0,d=2;
                     uint c;
        TH0=0;
        TL0=0;
        TMOD=0x01;
        EA=1;
        ET0=1;
        TR0=1;
        a=0;
        while(1)
                a++;
                d++;
                sector_erase();
                byte_program(0x00,a);
                byte_program(0x01,d);
                c=byte_read(0x00)*256+byte_read(0x01);
NE5532 发表于 2013-11-16 21:47 | 显示全部楼层
没有说什么E2芯片,确认不是FLASH哇?写1234呢?写一个字节又正确不呢?
评分
参与人数 1威望 +1 收起 理由
飞鸟yl + 1 单片机内部e2 问题已经解决 时间没设置好.
查看全部评分
crjab 发表于 2013-11-17 07:59 | 显示全部楼层
好贴就~~~~~顶一顶~~~~~~~~
