求救,关于STM32F205VC的AD转换,按官网固件改的代码,AD不启动
1801|1
 楼主| hansur 发表于 2013-11-20 10:39 | 显示全部楼层 |阅读模式
手头一个项目,用的是STM32F205,使用PA0-PA7作为AD输入采样,拟采用循环扫描,然后DMA自动读取结果到内存,但是仿真的时候AD没反应,求各位帮忙看看,是哪里设置不到位,还是我买到假的F205了?
代码如下:
  1. void HW_ADC_Configuration(void)
  3.     DMA_InitTypeDef DMA_InitStructure;
  4.     ADC_InitTypeDef       ADC_InitStructure;
  5.     ADC_CommonInitTypeDef ADC_CommonInitStructure;
  6.     NVIC_InitTypeDef NVIC_InitStructure;
  7.     RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2, ENABLE);
  8.     RCC_APB2PeriphResetCmd(RCC_APB2Periph_ADC1, ENABLE);
  9.     DMA_DeInit(DMA2_Stream0);
  10.     while (DMA_GetCmdStatus(DMA2_Stream0) != DISABLE);
  11.     DMA_InitStructure.DMA_Channel = DMA_Channel_0;
  12.     DMA_InitStructure.DMA_Memory0BaseAddr = (INT32U)uADCTEMP;
  13.     DMA_InitStructure.DMA_PeripheralBaseAddr = (INT32U)(&(ADC1->DR));;
  14.     DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
  15.     DMA_InitStructure.DMA_BufferSize = ADC_BUFF_SIZE;
  16.     DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  17.     DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  18.     DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  19.     DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  20.     DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  21.     DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  22.     DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
  23.     DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
  24.     DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
  25.     DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
  26.     DMA_Init(DMA2_Stream0, &DMA_InitStructure);
  27.     DMA_ITConfig(DMA2_Stream0, DMA_IT_TC, ENABLE);
  28.     DMA_Cmd(DMA2_Stream0, DISABLE);
  29.     // Enable ADC1_DMA interrput IRQ channel
  30.     NVIC_InitStructure.NVIC_IRQChannel = DMA2_Stream0_IRQn;
  31.     NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;          //指定抢占式优先级别0
  32.     NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;                 //指定响应优先级别0
  33.     NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  34.     NVIC_Init(&NVIC_InitStructure);
  35.     DMA_Cmd(DMA2_Stream0, ENABLE);
  36.     ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;
  37.     ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div8;
  38.     ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled;
  39.     ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_20Cycles;
  40.     ADC_CommonInit(&ADC_CommonInitStructure);
  41.     ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
  42.     ADC_InitStructure.ADC_ScanConvMode = ENABLE;
  43.     ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
  44.     ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
  45.     //ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T1_CC1;
  46.     ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  47.     ADC_InitStructure.ADC_NbrOfConversion = ADC_BUFF_SIZE;
  48.     ADC_Init(ADC1, &ADC_InitStructure);
  49.     ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_480Cycles);
  50.     ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_480Cycles);
  51.     ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 3, ADC_SampleTime_480Cycles);
  52.     ADC_RegularChannelConfig(ADC1, ADC_Channel_3, 4, ADC_SampleTime_480Cycles);
  53.     ADC_RegularChannelConfig(ADC1, ADC_Channel_4, 5, ADC_SampleTime_480Cycles);
  54.     ADC_RegularChannelConfig(ADC1, ADC_Channel_5, 6, ADC_SampleTime_480Cycles);
  55.     ADC_RegularChannelConfig(ADC1, ADC_Channel_6, 7, ADC_SampleTime_480Cycles);
  56.     ADC_RegularChannelConfig(ADC1, ADC_Channel_7, 8, ADC_SampleTime_480Cycles);
  57.     ADC_DMACmd(ADC1, ENABLE);
  58.     ADC_DMARequestAfterLastTransferCmd(ADC1, ENABLE);
  59.     ADC_Cmd(ADC1, ENABLE);
  60.     ADC_SoftwareStartConv(ADC1);
  61. }
  1. void ADC_DMA_IRQ(void)
  3.     static INT8U counter = 0;
  4.     static INT32U sum[ADC_BUFF_SIZE] = {0};
  5.     INT8U index;
  6.     for(index=0; index<ADC_BUFF_SIZE; index++)
  7.     {
  8.         sum[index] += uADCTEMP[index];
  9.     }
  10.     counter += 1;
  11.     if(counter >= ADC_CHMAX)
  12.     {
  13.         for(index=0; index<ADC_BUFF_SIZE; index++)
  14.         {
  15.             uADCvalue[index] = sum[index]/ADC_CHMAX;
  16.             sum[index] = 0;
  17.         }
  18.         counter = 0;
  19.     }
  20. }
  1. void DMA2_Stream0_IRQHandler(void)
  3.     if(DMA_GetITStatus(DMA2_Stream0, DMA_IT_TCIF0) != RESET)
  4.     {
  5.         ADC_DMA_IRQ();
  6.         DMA_ClearITPendingBit(DMA2_Stream0, DMA_IT_TCIF0);
  7.         DMA_ClearFlag(DMA2_Stream0, DMA_IT_TCIF0);
  8.     }
  9. }
现在仿真的结果是DMA的中断进不去,然后ADC转换的结果那个数组里边数据全是0不变。
 楼主| hansur 发表于 2013-11-21 10:02 | 显示全部楼层
难道大家用STM32F205都没有这个问题么,是不是我买到的芯片是假货啊?
