[51单片机] c8051f410Flash运用
1868|4
 楼主| wazibu 发表于 2013-12-3 14:46 | 显示全部楼层 |阅读模式
请问哪位高手用过c8051f410的Flash啊,请指点一下,最好能有c程序,参照一下,请好心的大师们帮帮忙
ayb_ice 发表于 2013-12-3 15:02 | 显示全部楼层
什么叫“用过”
wape271 发表于 2013-12-3 17:24 | 显示全部楼层
  1. /*
  2. 数据存储空间从地址0x0000到0x08ff;
  3. 扇区是512字节,擦除操作是整扇区擦除,所以Flash_Erase(0x0000)的擦除范围是0x0000到0x0200;
  4. 值得注意的是Flash_Erase(0x01ff)的擦除范围也是0x0000到0x0200;
  5. */
  6. #include "c8051f410.h"
  7. void Flash_Write(unsigned char source,unsigned int address);
  8. unsigned char Flash_Read(unsigned int addr);
  9. void Flash_Erase(unsigned int address);
  10. int i,j;
  11. unsigned char result;
  12. main()
  13. {
  14. OSCICN = 0x87;
  15. PCA0MD &= ~0x40;
  16. XBR0= 0x01;
  17.     XBR1= 0x40;
  18. //Flash_Erase(0x410);
  19. //Flash_Write(11,0x410);
  20. result=Flash_Read(0x410);
  21. i=0;
  22. }
  23. void Flash_Write(unsigned char source,unsigned int address)
  24. {
  25.     unsigned char EA_save;   // saves the current interrupt state
  26.     unsigned char xdata * data pwrite;
  27.     EA_save = EA;
  28.     EA = 0;                  // disable interrupts
  29.     pwrite = (unsigned char xdata *) address;
  30.     FLKEY = 0xA5;            // FLASH lock and key sequence 1
  31.     FLKEY = 0xF1;            // FLASH lock and key sequence 2
  32.     PSCTL = 0x01;            // Sets PSWE bit, Clears PSEE bit
  33.     *pwrite = source;      // Move the data to C8051F326 flash
  34.     PSCTL &= ~0x01;          // Clear PSWE so MOVX target XRAM
  35.     EA = EA_save;            // re-enable interrupts
  36. }
  37. void Flash_Erase(unsigned int address)
  38. {
  39.    unsigned char EA_save;   // saves the current interrupt state
  40.     unsigned char xdata * data pwrite;
  41.     EA_save = EA;
  42.     EA = 0;                  // disable interrupts
  43.     pwrite = (unsigned char xdata *) address;
  44.     FLKEY = 0xA5;            // FLASH lock and key sequence 1
  45.     FLKEY = 0xF1;            // FLASH lock and key sequence 2
  46.     PSCTL = 0x03;           // Sets PSWE bit, Sets PSEE bit
  47.     *pwrite = 0xff;        //擦除整个扇区
  48.     PSCTL &= ~0x03;          // Clear PSWE and PSEE so MOVX target XRAM
  49.     EA = EA_save;            // re-enable interrupts
  50. }
  51. unsigned char Flash_Read(unsigned int addr)
  52. {
  53.     unsigned char EA_save,Tmp_data;   // saves the current interrupt state
  54.     unsigned char code * data pread;
  55.     EA_save = EA;
  56.     EA = 0;                  // disable interrupts
  57. pread = (unsigned char code *) addr;
  58.     Tmp_data = *pread;        //读指定flash地址数据
  59.     EA = EA_save;            // re-enable interrupts
  60. return Tmp_data;
  61. }
airwill 发表于 2013-12-3 17:47 | 显示全部楼层
从 GOOGLE 搜一下, 就能找到一些了, 也到官网去找找.
ayb_ice 发表于 2013-12-4 08:17 | 显示全部楼层
官方例程一大把
