 在RM里面,你可以在"The two BD entries allows for an EVEN BD and ODD BD entry for each endpoint direction.This allows the microprocessor to process one BD while the USB-FS is processing the other BD"前面看到“The BDT resides on a 512 byte boundary in system memory and is pointed to by the BDT Page Registers. Every endpoint direction
 requires two eight-byte Buffer Descriptor entries. Therefore, a system with 16 fully bidirectional endpoints would require 512 bytes of system memory to implement the BDT.”结合起来就好理解了,一个BD占用8字节,每个endpoint(IN or OUT)占用两个BD,USB模块最多用到16个endpoint,因此整个BDT占用了16*2*16=512个字节,所以这个BDT的起始地址要放在512字节对齐的地方,因此BDT的结构可理解为:
 BD0//EP0 IN
 BD1//EP0 IN
 BD2//EP0 OUT
 BD3//EP0 OUT
 BD30//EP15 OUT
 BD31//EP15 OUT
 所以EVEN BD是指BD0,BD2,...,BD30, ODD BD是指BD1.BD3,...,BD31,当应用程序要发送数据是,比方说EP0 IN方向,USB device模式,发送信息给HOST(PC),那么将用到BD0和BD1,MCU初始化BD0后,把控制权交给USB-FS引擎处理发送,然后不用等待其发送完毕,就可以直接初始化BD1,为下一次发送做好准备,从而达到“Double buffering BDs in this way allows the USB-FS to easily transfer data at the maximum throughput provided by USB.”这样的效果。
 Hope that makes sense,
 B.R
 Kan
