F2812片内Flash烧写问题
5037|12
 楼主| 臻至水 发表于 2014-2-19 22:32 | 显示全部楼层 |阅读模式
请教问题!!程序烧写到最后一步出现下面的warning。网上查的都说修改cmd文件,但有没有具体写清楚的,有没有人知道这是什么情况??
zhangmangui 发表于 2014-2-19 22:52 | 显示全部楼层
看看你的CMD是RAM.CMD
烧写应该换为flash.cmd
 楼主| 臻至水 发表于 2014-2-20 09:00 | 显示全部楼层
看看你的CMD是RAM.CMD
烧写应该换为flash.cmd
这个已经换过了。。
zhangmangui 发表于 2014-2-20 09:10 | 显示全部楼层
这个已经换过了。。
贴CMD让大家看看
 楼主| 臻至水 发表于 2014-2-20 09:13 | 显示全部楼层
贴CMD让大家看看
这个是网上的F2812.cmd,没有修改过。
MEMORY
PAGE 0:    /* Program Memory */
           /* Memory (RAM/FLASH/OTP) blocks can be moved to PAGE1 for data allocation */
   ZONE0       : origin = 0x002000, length = 0x002000     /* XINTF zone 0 */
   ZONE1       : origin = 0x004000, length = 0x002000     /* XINTF zone 1 */
   RAML0       : origin = 0x008000, length = 0x001000     /* on-chip RAM block L0 */
   ZONE2       : origin = 0x080000, length = 0x080000     /* XINTF zone 2 */
   ZONE6       : origin = 0x100000, length = 0x080000     /* XINTF zone 6 */
   OTP         : origin = 0x3D7800, length = 0x000800     /* on-chip OTP */
   FLASHJ      : origin = 0x3D8000, length = 0x002000     /* on-chip FLASH */
   FLASHI      : origin = 0x3DA000, length = 0x002000     /* on-chip FLASH */
   FLASHH      : origin = 0x3DC000, length = 0x004000     /* on-chip FLASH */
   FLASHG      : origin = 0x3E0000, length = 0x004000     /* on-chip FLASH */
   FLASHF      : origin = 0x3E4000, length = 0x004000     /* on-chip FLASH */
   FLASHE      : origin = 0x3E8000, length = 0x004000     /* on-chip FLASH */
   FLASHD      : origin = 0x3EC000, length = 0x004000     /* on-chip FLASH */
   FLASHC      : origin = 0x3F0000, length = 0x004000     /* on-chip FLASH */
   FLASHA      : origin = 0x3F6000, length = 0x001F80     /* on-chip FLASH */
   CSM_RSVD    : origin = 0x3F7F80, length = 0x000076     /* Part of FLASHA.  Program with all 0x0000 when CSM is in use. */
   BEGIN       : origin = 0x3F7FF6, length = 0x000002     /* Part of FLASHA.  Used for "boot to Flash" bootloader mode. */
   CSM_PWL     : origin = 0x3F7FF8, length = 0x000008     /* Part of FLASHA.  CSM password locations in FLASHA */
   RAMH0       : origin = 0x3F8000, length = 0x001000     /* on-chip RAM block H0 */
/* ZONE7       : origin = 0x3FC000, length = 0x003FC0     /* XINTF zone 7 available if MP/MCn=1 */
   ROM         : origin = 0x3FF000, length = 0x000FC0     /* Boot ROM available if MP/MCn=0 */
   RESET       : origin = 0x3FFFC0, length = 0x000002     /* part of boot ROM (MP/MCn=0) or XINTF zone 7 (MP/MCn=1) */
   VECTORS     : origin = 0x3FFFC2, length = 0x00003E     /* part of boot ROM (MP/MCn=0) or XINTF zone 7 (MP/MCn=1) */
PAGE 1 :   /* Data Memory */
           /* Memory (RAM/FLASH/OTP) blocks can be moved to PAGE0 for program allocation */
           /* Registers remain on PAGE1                                                  */
   RAMM0       : origin = 0x000000, length = 0x000400     /* on-chip RAM block M0 */
   RAMM1       : origin = 0x000400, length = 0x000400     /* on-chip RAM block M1 */
   RAML1       : origin = 0x009000, length = 0x001000     /* on-chip RAM block L1 */
   FLASHB      : origin = 0x3F4000, length = 0x002000     /* on-chip FLASH */
   RAMH0       : origin = 0x3F9000, length = 0x001000     /* on-chip RAM block H0 */
/* Allocate sections to memory blocks.
   Note:
         codestart user defined section in DSP28_CodeStartBranch.asm used to redirect code
                   execution when booting to flash
         ramfuncs  user defined section to store functions that will be copied from Flash into RAM
SECTIONS
   /* Allocate program areas: */
   .cinit              : > FLASHA      PAGE = 0
   .pinit              : > FLASHA,     PAGE = 0
   .text               : > FLASHA      PAGE = 0
   codestart           : > BEGIN       PAGE = 0
   ramfuncs            : LOAD = FLASHD,
                         RUN = RAML0,
                         LOAD_START(_RamfuncsLoadStart),
                         LOAD_END(_RamfuncsLoadEnd),
                         RUN_START(_RamfuncsRunStart),
                         PAGE = 0
   csmpasswds          : > CSM_PWL     PAGE = 0
   csm_rsvd            : > CSM_RSVD    PAGE = 0
   /* Allocate uninitalized data sections: */
   .stack              : > RAMM0       PAGE = 1
   .ebss               : > RAML1       PAGE = 1
   .esysmem            : > RAMH0       PAGE = 1
    reset_vec          : > RAML1       PAGE = 1
   /* Initalized sections go in Flash */
   /* For SDFlash to program these, they must be allocated to page 0 */
   .econst             : > FLASHA      PAGE = 0
   .switch             : > FLASHA      PAGE = 0
   /* Allocate IQ math areas: */
   IQmath              : > FLASHC      PAGE = 0                  /* Math Code */
   IQmathFastTables    : > FLASHI      PAGE = 0   /* Math Tables in fast memory */
   IQmathTables        : > ROM         PAGE = 0, TYPE = NOLOAD   /* Math Tables In ROM */
   .reset              : > RESET,      PAGE = 0, TYPE = DSECT
   vectors             : > VECTORS     PAGE = 0, TYPE = DSECT
zhangmangui 发表于 2014-2-20 09:16 | 显示全部楼层
MEMORY
看看这个行不行
MEMORY
PAGE 0 :
   FLASHH      : origin = 0x3DC000, length = 0x006000
   FLASHP           : origin = 0x3E4000, length = 0x013FF6
   FLASHA      : origin = 0x3F6000, length = 0x001FF6   */
   PASSWDS     : origin = 0x3F7FF8, length = 0x000008
PAGE 1 :
   /* SARAM                     */
   RAMM0M1    : origin = 0x000000, length = 0x000800
   /* Peripheral Frame 0:   */
   DEV_EMU    : origin = 0x000880, length = 0x000180
   FLASH_REGS : origin = 0x000A80, length = 0x000060
   CSM        : origin = 0x000AE0, length = 0x000010
   XINTF      : origin = 0x000B20, length = 0x000020
   CPU_TIMER0 : origin = 0x000C00, length = 0x000008
   CPU_TIMER1 : origin = 0x000C08, length = 0x000008
   CPU_TIMER2 : origin = 0x000C10, length = 0x000008
   PIE_CTRL   : origin = 0x000CE0, length = 0x000020
   PIE_VECT   : origin = 0x000D00, length = 0x000100
   /* Peripheral Frame 1:   */
   ECAN_A     : origin = 0x006000, length = 0x000100
   ECAN_AMBOX : origin = 0x006100, length = 0x000100
   /* Peripheral Frame 2:   */
   SYSTEM     : origin = 0x007010, length = 0x000020
   SPI_A      : origin = 0x007040, length = 0x000010
   SCI_A      : origin = 0x007050, length = 0x000010
   XINTRUPT   : origin = 0x007070, length = 0x000010
   GPIOMUX    : origin = 0x0070C0, length = 0x000020
   GPIODAT    : origin = 0x0070E0, length = 0x000020
   ADC        : origin = 0x007100, length = 0x000020
   EV_A       : origin = 0x007400, length = 0x000040
   EV_B       : origin = 0x007500, length = 0x000040
   SPI_B      : origin = 0x007740, length = 0x000010
   SCI_B      : origin = 0x007750, length = 0x000010
   MCBSP_A    : origin = 0x007800, length = 0x000040
   /* CSM Password Locations */
   /* SARAM                    */
   RAML0L1    : origin = 0x008000, length = 0x002000
   RAMH0      : origin = 0x3F8000, length = 0x002000
   EXRAM          : origin = 0x100000, length = 0x010000
SECTIONS
   .reset              : > BEGIN       PAGE = 0
   .cinit              : > FLASHJ      PAGE = 0
   .text               : > FLASHP      PAGE = 0
   /* Allocate data areas: */
   .stack              : > RAMM0M1     PAGE = 1
   .ebss               : > RAML0L1     PAGE = 1
   .econst                           : > FLASHH      PAGE = 0
   .esysmem            : > RAML0L1      PAGE = 1
   IQmath              : > FLASHI      PAGE = 0   /* Math Code   flashi*/
   IQmathFastTables    : > FLASHI      PAGE = 0   /* Math Tables in fast memory  flashi*/
   IQmathTables        : > OTP         PAGE = 0   /* Math Tables In ROM */
   /* Allocate Peripheral Frame 0 Register Structures:   */
   DevEmuRegsFile      : > DEV_EMU     PAGE = 1
   FlashRegsFile       : > FLASH_REGS  PAGE = 1
   CsmRegsFile         : > CSM         PAGE = 1
   XintfRegsFile       : > XINTF       PAGE = 1
   CpuTimer0RegsFile   : > CPU_TIMER0  PAGE = 1
   CpuTimer1RegsFile   : > CPU_TIMER1  PAGE = 1
   CpuTimer2RegsFile   : > CPU_TIMER2  PAGE = 1
   PieCtrlRegsFile     : > PIE_CTRL    PAGE = 1
   PieVectTable                   : > PIE_VECT    PAGE = 1
   /* Allocate Peripheral Frame 2 Register Structures:   */
   ECanaRegsFile       : > ECAN_A      PAGE = 1
   ECanaMboxesFile     : > ECAN_AMBOX  PAGE = 1
   /* Allocate Peripheral Frame 1 Register Structures:   */
   SysCtrlRegsFile     : > SYSTEM      PAGE = 1
   SpiaRegsFile        : > SPI_A       PAGE = 1
   SciaRegsFile        : > SCI_A       PAGE = 1
   XIntruptRegsFile    : > XINTRUPT    PAGE = 1
   GpioMuxRegsFile     : > GPIOMUX     PAGE = 1
   GpioDataRegsFile    : > GPIODAT     PAGE = 1
   AdcRegsFile         : > ADC         PAGE = 1
   EvaRegsFile         : > EV_A        PAGE = 1
   EvbRegsFile         : > EV_B        PAGE = 1
   ScibRegsFile        : > SCI_B       PAGE = 1
   McbspaRegsFile      : > MCBSP_A     PAGE = 1
   CsmPwlFile          : > CSM_PWL     PAGE = 1
 楼主| 臻至水 发表于 2014-2-20 09:28 | 显示全部楼层
看看这个行不行
MEMORY
编译会出现error: FLASH_REGS memory range has already been specified这种错误
zhangmangui 发表于 2014-2-23 11:11 | 显示全部楼层
不好意思  问题解决了吗
 楼主| 臻至水 发表于 2014-2-28 15:46 | 显示全部楼层
不好意思  问题解决了吗
解决了,是我的source文件中多加载了一个.asm,这个文件对烧写有影响,去掉就正常了。
zhangmangui 发表于 2014-2-28 16:44 | 显示全部楼层
解决了就OK
拿起书本 发表于 2014-2-28 20:41 | 显示全部楼层
想要烧写flash 官方的F28335.cmd文件需不需要修改?不修改应该没什么问题吧?
 楼主| 臻至水 发表于 2014-2-28 20:59 | 显示全部楼层
我用的是F2812,我是没有修改就可以的,你可以先试试。
拿起书本 发表于 2014-2-28 21:05 | 显示全部楼层
谢谢,我试试看!
