[STM32F1] ucosii移植到stm32f103上,单步跑和连续跑结果不一样,求大家帮忙分析
1900|3
 楼主| aaammhua 发表于 2014-2-27 12:04 | 显示全部楼层 |阅读模式
代码:
S_EVENT        *MmiMsgMbox;
uint8_t  err1;
uint8_t led_status = 0;
uint32_t value;
uint32_t *number;
uint32_t FeedValue;
void task1(void *pdata)
        pdata=pdata;
        for(;;)
                LED_Off(LED_GPIO_PORT_B,LED_HL4_PIN);
//                 EXT485_Transmit_CMD(ENABLE);
//                 USART_PutChar( EXT485_USART,  0xAA);
//                 EXT485_Transmit_CMD(DISABLE);
    //uint8_t ReData[]={0xAA,0x55,0x01,0x00,0xff,0xff,0xff,0xff,0x02};
                FeedValue=0xAA;
                OSMboxPost(MmiMsgMbox,&FeedValue);
                OSTimeDlyHMSM(0,0,0,600);
void task2(void *pdata)
        pdata=pdata;
  for(;;)
                        number = OSMboxPend(MmiMsgMbox,10,&err1);
                        if(number == 0)
                        else
                        value = *number;
                        if(value == 0xAA)
                                LED_On(LED_GPIO_PORT_B,LED_HL4_PIN);
int main(void)
          Target_Init();                        /* Ä¿±ê»ù±¾³õʼ»¯ */
    OSInit();                                    /* ³õʼ»¯OS           */
    Tmr_TickInit();                        /* ³õʼ»¯OS Tick  */
          init_task_core();
//           OSTaskCreateExt(init_task_core, (void *)0, (OS_STK *)&InitTaskStk[OS_INIT_TASK_STACK_SIZE - 1],
//                                         OS_TASK_INIT_PRIO,
//                                         (OS_STK *)&InitTaskStk[0],
//                                         OS_INIT_TASK_STACK_SIZE,
//                                         (void *)0,
//                                         OS_TASK_OPT_STK_CHK | OS_TASK_OPT_STK_CLR);
    OSStart();                                /* Æô¶¯¶àÈÎÎñ»·¾³ */
          return(0);
static void init_task_core(void)
        //pdata = pdata;                                  /* ·ÀÖ¹±àÒëÆ÷¾¯¸æ*/
        application_init();
        //create_os_semphore();                /* ´´½¨Ó¦ÓÃÖеĴó¶àÊýÐźÅÁ¿*/
        create_os_mailbox();                /* ´´½¨Ó¦ÓÃÖеĴó¶àÊýÓÊÏäÏûÏ¢*/
        create_os_task();
static void  application_init (void)
        //UART_onfiguration();
        LED_GPIO_Init();
        LED_Off(LED_GPIO_PORT_B,LED_GREEN_PIN|LED_HL4_PIN | LED_HL3_PIN);
        ADC_GPIO_Configuration();
        DMA_Config();
        TIM1_Configuration();
        ADC1_config();
void create_os_mailbox(void)
        /* ÏûÏ¢ÓÊÏä´´½¨ */
        mmi_create_msg_mbox();
void create_os_task(void)
          OSTaskCreate(task1, (void *)0, (OS_STK *)&commuTaskStk[OS_485_TASK_STACK_SIZE-1],OS_485_TASK_PRIO);
    OSTaskCreate(task2, (void *)0, (OS_STK *)&LEDTaskStk[0],OS_LED_TASK_PRIO);
void mmi_create_msg_mbox(void)
        MmiMsgMbox = OSMboxCreate((void*)0);
单步跑LED会出现亮灭,但是连续跑就一直亮,停下时候在OS_EXIT_CRITICAL里面的      STRB    R2, [R1]这里,大家帮忙讲解下,谢谢!
Ketose 发表于 2014-2-27 12:52 | 显示全部楼层
间隔时间太短了,所以出现一直亮。
 楼主| aaammhua 发表于 2014-2-27 13:05 | 显示全部楼层
间隔时间太短了,所以出现一直亮。
600ms可以了吧,我单个任务的时候可以闪
outstanding 发表于 2014-2-27 13:35 | 显示全部楼层
代码 太长了
