基于STM8读取MPU6050的dwp中的数据问题
6198|2
 楼主| 激情的拼了 发表于 2014-3-5 13:30 | 显示全部楼层 |阅读模式
想要获得MPU6050的姿态角数据,从mpu的数据手册上看到有dwp功能可以快速获得四元数及欧拉角。
但是从mpu6050的fifo中读出的数据不对。
我是参考
void i2cinit(void)
  // 16 M晶振,400K TWI 速率
  TWBR=0x0a;
  TWAR=0x00;
  TWCR=0x94;
  TWSR=0x00;
void showfloat(unsigned char x,unsigned char y,float f_2show)
  unsigned char str2show[10];
  lcd_gotoxy(x,y);
  ftoa( f_2show,10,str2show);
  lcd_puts(str2show);
void showlong(unsigned char x,unsigned char y,long l_2show)
  unsigned char str2show[15];
  lcd_gotoxy(x,y);
  ltoa( l_2show,str2show);
  lcd_puts(str2show);
//以下TWI的基本操作函数是从马潮老师的书中复制而来,在此表示谢意
unsigned char i2cstart(void)
  TWCR=(1<<TWINT)|(1<<TWSTA)|(1<<TWEN);
  while(!(TWCR&(1<<TWINT))){};
  return 1;
void i2cstop(void)
  TWCR=(1<<TWINT)|(1<<TWEN)|(1<<TWSTO);
unsigned char i2cwbyte(unsigned char c)
  unsigned char ack=1;
  TWDR=c;
  TWCR=(1<<TWINT)|(1<<TWEN);
  if((TWSR&0xF8)!=TW_MT_SLA_ACK)
    ack=0;
  return ack;
unsigned char i2crbyte(unsigned char ack)
  if(ack)
    TWCR=(1<<TWINT)|(1<<TWEN)|(1<<TWEA);
  else
  return(TWDR);
unsigned char i2cread(unsigned char address)
  unsigned char data;
  i2cstart();
  i2cwbyte(i2cw);
  i2cwbyte(address);
  i2cstart();
  i2cwbyte(i2cr);
  data=i2crbyte(0);
  i2cstop();
  return data;
void i2cwrite(unsigned char address,unsigned char data)
  i2cstart();
  i2cwbyte(i2cw);
  i2cwbyte(address);
  i2cwbyte(data);
  i2cstop();
void readdmp(void)
  unsigned char dmpnum;
  i2cstart();
  i2cwbyte(i2cw);
  i2cwbyte(0x74);
  i2cstart();
  i2cwbyte(i2cr);
  for (dmpnum=0;dmpnum<41;dmpnum++)
    dmpdatas[dmpnum]=i2crbyte(1);
  dmpdatas[41]=i2crbyte(0);
  i2cstop();
long getdmplong(unsigned char address)
  long dmptempl;
  dmptempl = dmpdatas[address];
  dmptempl <<= 8;
  dmptempl |= dmpdatas[address+1];
  dmptempl <<= 8;
  dmptempl |= dmpdatas[address+2];
  dmptempl <<= 8;
  dmptempl |= dmpdatas[address+3];
  return dmptempl;
void getquaternion(void)
  quartf[0] = getdmplong(0)/1073741824.0;
  quartf[1] = getdmplong(4)/1073741824.0;
  quartf[2] = getdmplong(8)/1073741824.0;
  quartf[3] = getdmplong(12)/1073741824.0;
void getgyro(void)
  gyrof[0]=getdmplong(16)/16.384;
  gyrof[1]=getdmplong(20)/16.384;
  gyrof[2]=getdmplong(24)/16.384;
void getaccel(void)
  accelf[0]=getdmplong(28)/32768.0;
  accelf[1]=getdmplong(32)/32768.0;
  accelf[2]=getdmplong(36)/32768.0;
void init6050(void)
  i2cwrite(0x6b , 0b10000000);
  delay_ms(200);
  i2cwrite(0x6b , 0b00000001);                          //No sleep  , 3 PLL with X axis gyroscope reference
  i2cwrite(0x23 , 0b00000000);                          //FIFO 11111000 ,temp,gx,gy,gz,accel
  i2cwrite(0x19 , 0b00000101);                          //SMPLRT_DIV,+1 ,要能被 FIFO rate 整除
  i2cwrite(0x1a , 0b00000011);                          //00 111,8k ,other  1K  DLPF
  i2cwrite(0x1b , 0b00011000);                          //00011000  GYRO-CFG +-2000d/s
  i2cwrite(0x1c , 0b00000000);                          //ACCEL  +-2g/s
void loadfirmware(void)
  unsigned int datanum=0;
  unsigned char bank;
  unsigned lastbank=1;
  for (datanum=0;datanum<1929;datanum++)
     bank=datanum/256;
     if(lastbank!=bank){
       i2cwrite(0x6d,bank);
       i2cwrite(0x6e,0);
     i2cwrite(0x6f,dmpmemorydata[datanum]);
     lastbank=bank;
void loadcfgupd(void)
  unsigned char line;
  unsigned char bank;
  unsigned char datacounts=0;
  unsigned char bytes2write;
  unsigned char offset;
  unsigned char writingcounts;
  for (line=0;line<37;line++)
    bank=dmpcfgupddata[datacounts];
    datacounts++;
    offset=dmpcfgupddata[datacounts];
    datacounts++;
    bytes2write=dmpcfgupddata[datacounts];
    i2cwrite(0x6e,offset);
    for (writingcounts=0;writingcounts<bytes2write;writingcounts++)
     datacounts++;
        i2cwrite(0x6f,dmpcfgupddata[datacounts]);
    datacounts++;
void getyawpitchroll(void)
  // Roll = Atan2(2 *(Y * Z + W * X) , W * W -X * X -Y * Y + Z * Z)
yprf[0] = atan2(2 *(quartf[2] * quartf[3] + quartf[0] * quartf[1]) , quartf[0] * quartf[0] -quartf[1] * quartf[1] -quartf[2] * quartf[2] + quartf[3] * quartf[3])*57.3;
  // Pitch = asin(-2 * (X * Z - W * Y))
yprf[1]=asin(-2*(quartf[1]*quartf[3]-quartf[0]*quartf[2]))*57.3;
  // Yaw   = atan2(2 * (X * Y + W * Z) ,W * W + X * X - Y * Y - Z * Z)
yprf[2]=atan2(2*(quartf[1] * quartf[2] + quartf[0] * quartf[3]) , quartf[0] * quartf[0] +quartf[1] * quartf[1] -quartf[2] * quartf[2] - quartf[3] * quartf[3])*57.3;
void main(void)
unsigned int fifocounts;
// Bit Rate: 400.000 kHz
TWBR=0x0a;
TWAR=0x00;
TWCR=0x94;
TWSR=0x00;
// Alphanumeric LCD initialization
// Connections specified in the
// Project|Configure|C Compiler|Libraries|Alphanumeric LCD menu:
// RS - PORTA Bit 2
// RD - PORTA Bit 1
// EN - PORTA Bit 3
// D4 - PORTA Bit 4
// D5 - PORTA Bit 5
// D6 - PORTA Bit 6
// D7 - PORTA Bit 7
// Characters/line: 16
lcd_init(16);
i2cinit();
lcd_clear();
init6050();
loadfirmware();
loadcfgupd();
i2cwrite(0x70 , 0b00000011);
i2cwrite(0x71 , 0b00000000);
i2cwrite(0x6a , 0b11001100);
while(1)
   do
       do {
         fifocounts=i2cread(0x72);
         fifocounts=fifocounts<<8;
         fifocounts=fifocounts+i2cread(0x73);    //读出FIFO里有多少数据
         //showlong(12,3,fifocounts);
       while (fifocounts<42);
       readdmp();
   }while(fifocounts>=42);
   getquaternion();
   //getgyro();
   //getaccel();
   getyawpitchroll();
   showlong(12,0,dmpdatas[0]);      //显示一下原始数据,看有没有规律
   showlong(12,1,dmpdatas[1]);
   showfloat(0,0,yprf[0]);   //显示 ROLL PITCH YAW 值
   showfloat(0,1,yprf[1]);
   showfloat(0,2,yprf[2]);
   delay_ms(200);
   lcd_clear();
写的代码(不是用的库函数)。
有没有大虾能都指导一下不用dwp的库函数如何正确读出fifo中的内容。
 楼主| 激情的拼了 发表于 2014-3-6 08:34 | 显示全部楼层
错了,是使用mpu6050的dmp不是dwp。。。
lijianfeng-11 发表于 2015-10-14 17:54 | 显示全部楼层
一直没有找到STM8的代码,太冷门了
