跪求请大神帮忙看看我的程序~折磨我好久了~~
2499|9
 楼主| kxyyaonixingfu 发表于 2014-4-8 08:37 | 显示全部楼层 |阅读模式
dc, ADC, AD, pi, TE
dsp28335的程序,我想实现的功能是将采集到的ADC的值通过SCI发送到上位机的串口调试工具上,希望能在界面显示我想读的数据~
Uint16 sdataB[2];        // Send data for SCI-B
//Uint16 rdataB[2];        // Received data for SCI-B
Uint16 ConversionCount=0;
Uint16 test=0;
Uint16 Voltage[3];
interrupt void adc_isr(void);
interrupt void scibTxFifoIsr(void);
//interrupt void scibRxFifoIsr(void);
void scib_fifo_init(void);
void ADC_init(void);
//void scib_xmit(Uint16 a);
//void scib_msg(Uint16 * msg);
Uint16 flag;
void main()
   InitSysCtrl();
   InitScibGpio();
   EALLOW;
     SysCtrlRegs.HISPCP.all = ADC_MODCLK;        // HSPCLK = SYSCLKOUT/ADC_MODCLK
   EDIS;
   InitXintf16Gpio();
   DINT;
   InitPieCtrl();
   IER = 0x0000;
   IFR = 0x0000;
   InitPieVectTable();
   InitAdc();
   scib_fifo_init();
   ADC_init();
        EALLOW;  // This is needed to write to EALLOW protected register
       PieVectTable.ADCINT = &adc_isr;
       //PieVectTable.SCIRXINTB=&scibRxFifoIsr;
        PieVectTable.SCITXINTB= &scibTxFifoIsr;
        EDIS;
        PieCtrlRegs.PIECTRL.bit.ENPIE = 1;   // Enable the PIE block
        PieCtrlRegs.PIEIER1.bit.INTx6 = 1;      //adc中断1.6
        //PieCtrlRegs.PIEIER9.bit.INTx3=1;     // PIE Group 9, INT3
        PieCtrlRegs.PIEIER9.bit.INTx4=1;     //  9.4发送中断
        IER |= M_INT1; // Enable CPU Interrupt 1
        IER |= M_INT9;        // Enable CPU INT
          EINT;          // Enable Global interrupt INTM
          ERTM;  // For this example, init the ADC
          AdcRegs.ADCTRL2.all = 0x2800;
for(;;);
        ConversionCount++;
        //Uint16 i;
     // AdcRegs.ADCTRL2.all = 0x2800;
      //while(AdcRegs.ADCST.bit.INT_SEQ1 == 0);
      //for(i=0;i<3;i++)
              Voltage[0]=((AdcRegs.ADCRESULT0) >>4);
            // Voltage[1]=AdcRegs.ADCRESULT1 >>4;
             AdcRegs.ADCST.bit.INT_SEQ1_CLR = 1;       // Clear INT SEQ1 bit
             AdcRegs.ADCTRL2.bit.RST_SEQ1 = 1;         // Reset SEQ1
            PieCtrlRegs.PIEACK.all = PIEACK_GROUP1;   // Acknowledge interrupt to PIE
             DELAY_US(100);
  //return;
   Uint16 i=0;
  test++;
    for(i=0; i<2; i++)
          ScibRegs.SCITXBUF=sdataB;     // Send data
      //while(ScibRegs.SCICTL2.bit.TXRDY!=1){}
   // text++;
        ScibRegs.SCIFFTX.bit.TXFFINTCLR=1;  // Clear Interrupt flag
        PieCtrlRegs.PIEACK.all|=0x100;      // Issue PIE ACK
        EINT;
/*interrupt void scibRxFifoIsr(void)
    Uint16 i;
        for(i=0;i<8;i++)
                //ScibRegs.SCIRXBUF.all=Voltage1[ConversionCount];
            sdataB=ScibRegs.SCIRXBUF.all;         // Read data
        ScibRegs.SCIFFRX.bit.RXFFOVRCLR=1;  // Clear Overflow flag
        ScibRegs.SCIFFRX.bit.RXFFINTCLR=1;         // Clear Interrupt flag
        PieCtrlRegs.PIEACK.all|=0x100;          // Issue PIE ack
void scib_fifo_init()
   ScibRegs.SCICCR.all =0x0007;    // 1 stop bit,  No loopback
                                   // No parity,8 char bits,
                                   // async mode, idle-line protocol
   ScibRegs.SCICTL1.all =0x0003;   // enable TX, RX, internal SCICLK,
                                   // Disable RX ERR, SLEEP, TXWAKE
   ScibRegs.SCICTL1.bit.TXENA=1;    //发送使能
   ScibRegs.SCICTL2.bit.TXINTENA =1;
  // ScibRegs.SCICTL2.bit.RXBKINTENA =1;
   ScibRegs.SCIHBAUD    =0x01;
   ScibRegs.SCILBAUD    =0xE7 ;//9600
//  ScibRegs.SCICCR.bit.LOOPBKENA =0; // Enable loop back
   ScibRegs.SCIFFTX.all=0xC020;    //发送FIFO为空时发生中断
  // ScibRegs.SCIFFRX.all=0x0028;
  ScibRegs.SCIFFCT.all=0x00;
   ScibRegs.SCICTL1.all =0x0023;     // Relinquish SCI from Reset,禁止接收错误中断
   ScibRegs.SCIFFTX.bit.TXFIFOXRESET=1;//重新使能接收寄存器
  // ScibRegs.SCIFFRX.bit.RXFIFORESET=1;
   void ADC_init()
      // Specific ADC setup for this example:
           AdcRegs.ADCTRL1.bit.ACQ_PS = ADC_SHCLK;  // 连续采样Sequential mode: Sample rate   = 1/[(2+ACQ_PS)*ADC clock in ns]
                         //                     = 1/(3*40ns) =8.3MHz (for 150 MHz SYSCLKOUT)
                                             //                     = 1/(3*80ns) =4.17MHz (for 100 MHz SYSCLKOUT)
                                             // If Simultaneous mode enabled: Sample rate = 1/[(3+ACQ_PS)*ADC clock in ns]
    AdcRegs.ADCTRL3.bit.ADCCLKPS = ADC_CKPS;
    AdcRegs.ADCTRL3.bit.SMODE_SEL=0;          //顺序采样
    AdcRegs.ADCTRL1.bit.SEQ_CASC = 1;         // 级联模式(=0为双序列模式)
    AdcRegs.ADCCHSELSEQ1.bit.CONV00 = 0x0;    //  采样ADCINA0和ADCINB0
    AdcRegs.ADCTRL1.bit.CONT_RUN = 1;         // 连续转换模式
    AdcRegs.ADCTRL1.bit.SEQ_OVRD = 1;         // Enable Sequencer override feature
    AdcRegs.ADCCHSELSEQ1.all = 0x0;           // Initialize all ADC channel selects to A0
   // AdcRegs.ADCCHSELSEQ2.all = 0x0;
   // AdcRegs.ADCCHSELSEQ3.all = 0x0;
   // AdcRegs.ADCCHSELSEQ4.all = 0x0;
    AdcRegs.ADCMAXCONV.bit.MAX_CONV1 = 0x0;
    // convert and store in 8 results registers最大采样通道数为2,一次采两个通道,总共可采4个通道
// Start SEQ1   软件触发
    AdcRegs.ADCTRL2.all = 0x2800;//0x2800;  //AdcRegs.ADCTRL2.bit.SOC_SEQ1=1; 软件触发,中断使能
//0800为定时中断触发转换,中断使能。
zhangmangui 发表于 2014-4-8 22:15 | 显示全部楼层
好吧   曾经用过的代码   也是实现相关参数的上传和上位机下发控制
你参考一下吧
zhangmangui 发表于 2014-4-8 22:16 | 显示全部楼层
代码可能有些乱  仅供参考
拿起书本 发表于 2014-4-9 09:12 | 显示全部楼层
参考学习一下版主提供的代码,感谢分享,版主好人,顶!
 楼主| kxyyaonixingfu 发表于 2014-4-12 21:40 | 显示全部楼层
才看见~~~我这怎么没有消息提醒呢·~~拜谢~~~~@zhangmangui
hudi008 发表于 2014-4-13 20:10 | 显示全部楼层
这个好复杂呢
970253146 发表于 2015-12-25 23:21 | 显示全部楼层
我最近也在搞这一块
zhangjin_comeon 发表于 2015-12-30 22:10 | 显示全部楼层
版主的代码    下载看看了
edishen 发表于 2015-12-30 22:19 | 显示全部楼层
controlSUITE下载了吗
chenci2013 发表于 2015-12-30 22:41 | 显示全部楼层
楼主遇到了什么问题呢
