固件下载问题
1086|2
 楼主| jinpaidianzi 发表于 2014-4-30 23:06 | 显示全部楼层 |阅读模式
照着PC机示例程序写了一个PC程序,第一次打开PC程序下载FX2固件程序后能正常使用。关掉程序再打开,再下载固件程序,就不能向USB传输数据了,但如果不再次下载固件程序,程序使用是正常的。请问FX2在设备枚举和重枚举的时候有啥要注意的,导致我这种错误。
我觉得问题应该就是在FX2初始化,枚举重枚举那里。我FX2只要reset一下就全好了,不reset再下载固件程序就不行。但是我不清楚这部分该怎么做,可以多次下载固件程序不出错。是不是每次下载之前都要重新get_address之类的
下面是固件下载程序,就是原来的示例程序,没改过
BOOL CCYDEMODlg::OnDownloadFirmware(LPTSTR strdownloadfile,BOOL displaycharen)
        // TODO: Add your control notification handler code here
        HANDLE hDevice=NULL;
        BOOL   bResult = FALSE;
        ULONG  nBytes;
        char   DeviceName[256] = "";
//        char   tempbuff[256];
//        char   temp[256];
    unsigned char buffer[MAX_BIX_SIZE];
    int    numreadfile  = 0;
//        int i;
        HWND hdlg = NULL;
        VENDOR_REQUEST_IN        myRequest;
        BOOL Downloadresult = FALSE;
        m_strTestDisplay+="\r\n";
        // Open the driver
        if(!bOpenDriver(&hDevice,m_strName.GetBuffer(m_strName.GetLength())))
                m_strTestDisplay+="No available device!\r\nPlease try again!\r\n";
                UpdateData(FALSE);
                return Downloadresult;
        myRequest.bRequest = 0xA0;
        myRequest.wValue = 0xE600;
        myRequest.wIndex = 0x00;
        myRequest.wLength = 0x01;
        myRequest.bData = 1;        //锁定
        myRequest.direction = 0x00;
        bResult = DeviceIoControl (hDevice,
                IOCTL_Ezusb_VENDOR_REQUEST,
                &myRequest,
                sizeof(VENDOR_REQUEST_IN),
                NULL,
                0,
                &nBytes,
                NULL);
        if (bResult!=TRUE)
                m_strTestDisplay+="Error!Can't lock USB chip\r\n";
                CloseHandle(hDevice);
        else {
                m_strTestDisplay+="Success!\r\nUSB chip has been locked!\r\n";
        UpdateData(FALSE);
        CFile MyFile;
        if (!MyFile.Open(strdownloadfile,CFile::modeRead,NULL))
                MessageBox("Can't open the config file!","Config Error",MB_ICONERROR);
        else
                MyFile.Read(buffer,MAX_BIX_SIZE);        //读取文件
                numreadfile = MAX_BIX_SIZE;
                CString strfilelength;
                strfilelength.Format("The config file size is %d Bytes\r\n",numreadfile);
                m_strTestDisplay+=strfilelength;
                UpdateData(FALSE);
        MyFile.Close();
                IOCTL_Ezusb_ANCHOR_DOWNLOAD,
                buffer,
                numreadfile,
                NULL,
                0,
                &nBytes,
                NULL);
        if (bResult!=TRUE)
                m_strTestDisplay+="Error!\r\nDownlod config file Fail!\r\n";
    else
                m_strTestDisplay+="Success!\r\nConfig file has been downloaded\r\n";
        UpdateData(FALSE);
        myRequest.bData = 0;        //复位
                &myRequest,
                NULL,
                0,
                &nBytes,
                NULL);
        if (bResult!=TRUE)
                m_strTestDisplay+="Error!\r\nReset USB chip fail!\r\n";
        else {
                m_strTestDisplay+="Success!\r\nUSB chip has been reset\r\n";
                Downloadresult = TRUE;
        UpdateData(FALSE);
kk5290122 发表于 2014-6-17 20:45 | 显示全部楼层
lz是在做USB通信么??
