这是CMD文件,从官网下的,只- MEMORY
- PAGE 0: /* Program Memory */
- /* Memory (RAM/FLASH/OTP) blocks can be moved to PAGE1 for data allocation */
- ZONE0 : origin = 0x002000, length = 0x002000 /* XINTF zone 0 */
- ZONE1 : origin = 0x004000, length = 0x002000 /* XINTF zone 1 */
- RAML0 : origin = 0x008000, length = 0x001000 /* on-chip RAM block L0 */
- ZONE2 : origin = 0x080000, length = 0x080000 /* XINTF zone 2 */
- ZONE6 : origin = 0x100000, length = 0x080000 /* XINTF zone 6 */
- OTP : origin = 0x3D7800, length = 0x000800 /* on-chip OTP */
- FLASHJ : origin = 0x3D8000, length = 0x002000 /* on-chip FLASH */
- FLASHI : origin = 0x3DA000, length = 0x002000 /* on-chip FLASH */
- FLASHH : origin = 0x3DC000, length = 0x004000 /* on-chip FLASH */
- FLASHG : origin = 0x3E0000, length = 0x004000 /* on-chip FLASH */
- FLASHF : origin = 0x3E4000, length = 0x004000 /* on-chip FLASH */
- FLASHE : origin = 0x3E8000, length = 0x004000 /* on-chip FLASH */
- FLASHD : origin = 0x3EC000, length = 0x004000 /* on-chip FLASH */
- FLASHC : origin = 0x3F0000, length = 0x004000 /* on-chip FLASH */
- FLASHA : origin = 0x3F6000, length = 0x001F80 /* on-chip FLASH */
- CSM_RSVD : origin = 0x3F7F80, length = 0x000076 /* Part of FLASHA. Program with all 0x0000 when CSM is in use. */
- BEGIN : origin = 0x3F7FF6, length = 0x000002 /* Part of FLASHA. Used for "boot to Flash" bootloader mode. */
- CSM_PWL : origin = 0x3F7FF8, length = 0x000008 /* Part of FLASHA. CSM password locations in FLASHA */
- /* ZONE7 : origin = 0x3FC000, length = 0x003FC0 /* XINTF zone 7 available if MP/MCn=1 */
- ROM : origin = 0x3FF000, length = 0x000FC0 /* Boot ROM available if MP/MCn=0 */
- RESET : origin = 0x3FFFC0, length = 0x000002 /* part of boot ROM (MP/MCn=0) or XINTF zone 7 (MP/MCn=1) */
- VECTORS : origin = 0x3FFFC2, length = 0x00003E /* part of boot ROM (MP/MCn=0) or XINTF zone 7 (MP/MCn=1) */
- PAGE 1 : /* Data Memory */
- /* Memory (RAM/FLASH/OTP) blocks can be moved to PAGE0 for program allocation */
- /* Registers remain on PAGE1 */
- RAMM0 : origin = 0x000000, length = 0x000400 /* on-chip RAM block M0 */
- RAMM1 : origin = 0x000400, length = 0x000400 /* on-chip RAM block M1 */
- RAML1 : origin = 0x009000, length = 0x001000 /* on-chip RAM block L1 */
- FLASHB : origin = 0x3F4000, length = 0x002000 /* on-chip FLASH */
- RAMH0 : origin = 0x3F8000, length = 0x002000 /* on-chip RAM block H0 */
- ZONE2tf : origin = 0x084000, length = 0x001FFF
- /* Allocate sections to memory blocks.
- Note:
- codestart user defined section in DSP28_CodeStartBranch.asm used to redirect code
- execution when booting to flash
- ramfuncs user defined section to store functions that will be copied from Flash into RAM
- SECTIONS
- /* Allocate program areas: */
- .cinit : > FLASHA PAGE = 0
- .pinit : > FLASHA, PAGE = 0
- .text : > FLASHA PAGE = 0
- codestart : > BEGIN PAGE = 0
- ramfuncs : LOAD = FLASHD,
- RUN = RAML0,
- LOAD_START(_RamfuncsLoadStart),
- LOAD_END(_RamfuncsLoadEnd),
- RUN_START(_RamfuncsRunStart),
- PAGE = 0
- csmpasswds : > CSM_PWL PAGE = 0
- csm_rsvd : > CSM_RSVD PAGE = 0
- /* Allocate uninitalized data sections: */
- .stack : > RAMM0 PAGE = 1
- .ebss : > RAML1 PAGE = 1
- .esysmem : > RAMH0 PAGE = 1
- /* Initalized sections go in Flash */
- /* For SDFlash to program these, they must be allocated to page 0 */
- .econst : > FLASHA PAGE = 0
- .switch : > FLASHA PAGE = 0
- /* Allocate IQ math areas: */
- IQmath : > FLASHC PAGE = 0 /* Math Code */
- IQmathTables : > ROM PAGE = 0, TYPE = NOLOAD /* Math Tables In ROM */
- /* .reset is a standard section used by the compiler. It contains the */
- /* the address of the start of _c_int00 for C Code. /*
- /* When using the boot ROM this section and the CPU vector */
- /* table is not needed. Thus the default type is set here to */
- /* DSECT */
- .reset : > RESET, PAGE = 0, TYPE = DSECT
- vectors : > VECTORS PAGE = 0, TYPE = DSECT
- FFTipcb3 ALIGN(256) : {} > RAMH0 PAGE=1
- FFTipcb4 ALIGN(256) : {} > RAMH0 PAGE=1
- FFTmag : > RAMH0 PAGE=1
- FFTtf : > RAML0 PAGE=0
修改了存放fft数据的地方,我感觉还是FFT部分配置的有问题在RAM里是可以的,固化到Flash里就不行了,其他部分都可以在FLASH正常运行
烧写的时候还会出现错误
Warning: This program contains initialized RAM data.
It may run successfully under Code Composer Studio
but not as a standalone system because of this. If
your Flash program requires initialized data in RAM,
you will need to write Flash code to initialize RAM memory.
Erase/Program/Verify Operation succeeded
**** End Erase/Program/Verify Operation. ***
把和FFT相关的部分去掉就不会出现这个警告
