#include <msp430.h>
unsigned char TXByteCtr;
unsigned char RXByteCtr;
unsigned char second;
unsigned char read=0;
int main(void)
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
P1SEL |= BIT6 + BIT7; // Assign I2C pins to USCI_B0
P1SEL2|= BIT6 + BIT7; // Assign I2C pins to USCI_B0
UCB0CTL1 |= UCSWRST; // Enable SW reset
UCB0CTL0 = UCMST + UCMODE_3 + UCSYNC; // I2C Master, synchronous mode
UCB0CTL1 = UCSSEL_2 + UCSWRST; // Use SMCLK, keep SW reset
UCB0BR0 = 12; // fSCL = SMCLK/12 = ~100kHz
UCB0BR1 = 0;
UCB0I2CSA = 0xD0>>1; // Slave Address is 048h
UCB0CTL1 &= ~UCSWRST; // Clear SW reset, resume operation
while (1)
IE2 |= UCB0TXIE; // Enable TX interrupt
IE2 &= ~UCB0RXIE;
TXByteCtr = 1; // Load TX byte counter
while (UCB0CTL1 & UCTXSTP); // Ensure stop condition got sent
UCB0CTL1 |= UCTR + UCTXSTT; // I2C TX, start condition
__bis_SR_register(CPUOFF + GIE); // Enter LPM0 w/ interrupts
// Remain in LPM0 until all data
// is TX'd
IE2 |= UCB0RXIE;
IE2 &= ~UCB0TXIE;
RXByteCtr = 1;
UCB0CTL1 &= ~UCTR;
UCB0CTL1 |= UCTXSTT;
// The USCIAB0TX_ISR is structured such that it can be used to transmit any
// number of bytes by pre-loading TXByteCtr with the byte count. Also, TXData
// points to the next byte to transmit.
#pragma vector = USCIAB0TX_VECTOR
__interrupt void USCIAB0TX_ISR(void)
if (TXByteCtr) // Check TX byte counter
UCB0TXBUF = 0x00; // Load TX buffer
TXByteCtr--; // Decrement TX byte counter
else
UCB0CTL1 |= UCTXSTP; // I2C stop condition
IFG2 &= ~UCB0TXIFG; // Clear USCI_B0 TX int flag
__bic_SR_register_on_exit(CPUOFF); // Exit LPM0
#pragma vector = USCIAB0RX_VECTOR
__interrupt void USCIAB0RX_ISR(void)
if (RXByteCtr) // Check TX byte counter
second=UCB0RXBUF; // Load TX buffer
RXByteCtr--; // Decrement TX byte counter
else
IFG2 &= ~UCB0RXIFG; // Clear USCI_B0 TX int flag
