本来应该打印1:0.012:0.151:0.012:0.15
- void interrupt0() interrupt 0
- timercount = 0; //reset
- IE = 0x0; //disable all interrupt
- // TCON = 0x05; //0b0000 0101
- //shutdown t0 and t1
- //reset t0 and t1 interrupt flag bit
- if(INTc == 0) //state1
- //TCON = 0x01;//int0 negative edge triggered,int0
- //low voltage triggered
- uart();
- IE = 0x83; //enable t0 and int0 inerrupt
- TR0 = 1;
- else //state2
- uart();
- IE = 0x89; //enable UART1,t1 and int0 interrupt
- TR1 = 1;
- INTc = ~INTc;
- void uart()
- unsigned char i;
- unsigned char state1data[7]={"1:0.01"};
- unsigned char state2data[7]={"2:0.15"};
- RCAP2L = 0xdc;
- RCAP2H = 0xff;
- T2CON = 0x34; //timer2
- SCON = 0x40; //0b0100 0000
- //mode 1, receive disabled,
- PCON = 0x0; //baudrate no multiply, frame no error check
