[STM32F1] 同时配置了外部中断0和13,中断0能正常运行13总是进不去中断
1607|6
 楼主| sunkaokao 发表于 2014-9-13 19:50 | 显示全部楼层 |阅读模式
我同时配置了外部中断0和13,中断13一直进不去,进入调试模式发现EXTI_PR的PR13一直为1,我应该怎么做才能正常运行中断程序,这是我的代码:
/*********************main.c******************************/
#include "stm32f10x.h"
#include "Led.h"
#include "sk_exti.h"
int main(void)
        Led_Config();
        LED1(ON);
        EXTI_Config();
        while(1)
/*********************sk_exti.c***************************************/
void EXTI_GPIO_Config(void)
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOC | \
                               RCC_APB2Periph_AFIO, ENABLE);                     //´ò¿ªGPIOA,GPIOC,AFIOʱÖÓ
        /*    É趨GPIOA_Pin0ºÍGPIOC_Pin_13ΪÉÏÀ­ÊäÈëģʽ   */
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
        GPIO_Init(GPIOC, &GPIO_InitStructure);
static void NVIC_Config(void)
        NVIC_InitTypeDef NVIC_InitStructure;
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);                  //ÖжϷÖ×é1
        NVIC_InitStructure.NVIC_IRQChannel = EXTI0_IRQn;                 //ÅäÖÃÍⲿÖжÏ1µÄÖжÏÓÅÏȼ¶
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStructure);
        NVIC_InitStructure.NVIC_IRQChannel = EXTI15_10_IRQn;                 //ÅäÖÃÍⲿÖжÏ13µÄÖжÏÓÅÏȼ¶
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
void EXTI_Config(void)
        EXTI_InitTypeDef EXTI_InitStructure;
        GPIO_EXTILineConfig(GPIO_PortSourceGPIOA, GPIO_PinSource0);      //½«GPIOA_Pin_0ÓëÍⲿÖжÏ1ͨµÀÁ¬½Ó
        GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource13);     //½«GPIOC_Pin_13ÓëÍⲿÖжÏ13ͨµÀÁ¬½Ó
        NVIC_Config();
        EXTI_InitStructure.EXTI_Line = EXTI_Line0 | EXTI_Line13;          //¿ªÍⲿÖжÏ0ºÍ13µÄÖжÏ
        EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;               //ÉèÖÃΪÖжÏģʽ
        EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;           //ϽµÑØ´¥·¢
        EXTI_InitStructure.EXTI_LineCmd = ENABLE;
        EXTI_Init(&EXTI_InitStructure);
/**************************中断程序***************************/
void EXTI0_IRQHandler(void)
        if(EXTI_GetITStatus(EXTI_Line0) != RESET)
                GPIO_WriteBit(GPIOC, GPIO_Pin_4, (BitAction)(1-GPIO_ReadOutputDataBit(GPIOC, GPIO_Pin_4)));
                EXTI_ClearITPendingBit(EXTI_Line0);
void EXTI15_10_IRQHandler(void)
        if(EXTI_GetITStatus(EXTI_Line13) != RESET)
                LED3(ON);
                EXTI_ClearITPendingBit(EXTI_Line13);
/****************Led.c***************/
#include "Led.h"
void Led_Config(void)
        /*ÅäÖÃGPIOB_Pin_0,   GPIOC_Pin_3,4  */
        GPIO_InitTypeDef GPIO_InitStrucute;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC, ENABLE);
        GPIO_InitStrucute.GPIO_Pin = GPIO_Pin_0;
        GPIO_InitStrucute.GPIO_Mode = GPIO_Mode_Out_PP;
        GPIO_InitStrucute.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_Init(GPIOB, &GPIO_InitStrucute);
        GPIO_InitStrucute.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_4;
//        GPIO_InitStrucute.GPIO_Mode = GPIO_Mode_Out_PP;
//        GPIO_InitStrucute.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_Init(GPIOC, &GPIO_InitStrucute);
        GPIO_SetBits(GPIOB, GPIO_Pin_0);                                 //¹Ø±ÕLED1
        GPIO_SetBits(GPIOC, GPIO_Pin_3 | GPIO_Pin_4);                    //¹Ø±ÕLED2, LED3
mmuuss586 发表于 2014-9-13 22:01 | 显示全部楼层
仔细看下,是不是这个中断脚;
 楼主| sunkaokao 发表于 2014-9-14 11:25 | 显示全部楼层
管脚都是对的,而且我换成GPIOB_Pin_13实验还是进不去中断,我进入调试模式在EXTI_Config()配置完成后发现EXTI_PR挂起寄存器PR13一直为1,我没懂这个地方的意思
搞IT的 发表于 2014-9-14 22:19 | 显示全部楼层
进来看看
悲伤流逝 发表于 2014-9-15 09:28 | 显示全部楼层
学习学习
diweo 发表于 2014-9-15 12:43 | 显示全部楼层
没看到哪里调用EXTI_GPIO_Config()啊
 楼主| sunkaokao 发表于 2014-9-15 20:04 | 显示全部楼层
谢谢diweo,果然是没调用EXTI_GPIO_Config(),还有个原因是我通过实验板看现象我LED3对应的管脚搞错了,我以为是错误情况,其实是对了
