/* Configure the IO matrix for the device. On the FX3 DVK board,
* the COM port is connected to the IO(53:56). This means that
* either DQ32 mode should be selected or lppMode should be set
* to UART_ONLY. Here we are choosing UART_ONLY configuration. */
在GPIO的例程里,看到这样一段话,说的是把53-56引脚配置为uart的数据引脚,但是我在例程里完全找不到相关的配置,求大神们指教 |
