[Atmel] 用AtmelStudio6.2跑mega16例程(34)INT0记数
1080|0
 楼主| ddllxxrr 发表于 2014-10-15 20:41 | 显示全部楼层 |阅读模式
用一个按键接到INT0,按一下记一个数,并且显示。按另一个清零。
仿真截图:
ATMEL Studio6.2编译通过截图:
程序:
  1. /*
  2. * GccApplication19.c
  3. *
  4. * Created: 2014-10-15 20:16:25
  5. *  Author: Administrator
  6. */
  7. #define F_CPU 0x8000000UL
  8. #include <avr/io.h>
  9. #include <avr/interrupt.h>
  10. #include <stdint.h>
  11. #define KEY_CLEAR_ON() ((PIND & _BV(PD6))==0x00)
  12. const uint8_t DSY_CODE[] = {0x3f,0x06,0x58,0x4f,0x66,0x60,0x70,0x07,0x7F,0x6F,0x00};
  13.
  14. uint8_t Count = 0;
  15. uint8_t Display_Buffer[3] = {0,0,0};
  16.
  17. void Show_Count_ON_DSY()
  18. {
  19.    Display_Buffer[2] = Count/100;
  20.    Display_Buffer[1] = Count % 100 / 10;
  21.    Display_Buffer[0] = Count % 10;
  22.
  23.    if(Display_Buffer[2] == 0)
  24.    {
  25.           Display_Buffer[2] = 10;
  26.           if(Display_Buffer[1] == 0) Display_Buffer[1] = 10;
  27.    }
  28.    PORTA = DSY_CODE[Display_Buffer[2]];
  29.    PORTB = DSY_CODE[Display_Buffer[1]];
  30.    PORTC = DSY_CODE[Display_Buffer[0]];
  31. }
  32. int main(void)
  33. {
  34.     DDRA = 0xFF;PORTA = 0xFF;
  35.         DDRB = 0xFF;PORTB = 0xFF;
  36.         DDRC = 0xFF;PORTC = 0xFF;
  37.         DDRD = 0x00;PORTD = 0xFF;
  38.         MCUCR = 0x02;GICR = 0x40;
  39.         SREG = 0x80;
  40.
  41.         while(1)
  42.     {
  43.         if (KEY_CLEAR_ON())Count = 0;
  44.                 Show_Count_ON_DSY();
  45.     }
  46. }
  47. ISR(INT0_vect)
  48. {
  49.         Count++;
  50.
  51. }
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2404
