MPLAB ICD 2燒錄程式出現錯誤代號為:ICD0161
6167|2
 楼主| lurker_soo 发表于 2007-4-24 21:11 | 显示全部楼层 |阅读模式
MPLAB&nbsp;ICD&nbsp;2&nbsp;Ready<br />Connecting&nbsp;to&nbsp;MPLAB&nbsp;ICD&nbsp;2<br />...Connected<br />Setting&nbsp;Vdd&nbsp;source&nbsp;to&nbsp;MPLAB&nbsp;ICD&nbsp;2<br />Target&nbsp;Device&nbsp;PIC16F737&nbsp;found,&nbsp;revision&nbsp;=&nbsp;Rev&nbsp;0x1<br />...Reading&nbsp;ICD&nbsp;Product&nbsp;ID<br />Running&nbsp;ICD&nbsp;Self&nbsp;Test<br />...Passed<br />MPLAB&nbsp;ICD&nbsp;2&nbsp;Ready<br />Programming&nbsp;Target...<br />...Validating&nbsp;configuration&nbsp;fields<br />...Erasing&nbsp;Part<br />...Programming&nbsp;Program&nbsp;Memory&nbsp;(0x0&nbsp;-&nbsp;0x1F)<br />...Programming&nbsp;User&nbsp;IDs<br />Verifying...<br />...Program&nbsp;Memory<br />ICD0161:&nbsp;Verify&nbsp;failed&nbsp;(MemType&nbsp;=&nbsp;Program,&nbsp;Address&nbsp;=&nbsp;0x0,&nbsp;Expected&nbsp;Val&nbsp;=&nbsp;0x2810,&nbsp;Val&nbsp;Read&nbsp;=&nbsp;0x0)<br />ICD0275:&nbsp;&nbsp;Programming&nbsp;failed.<br />MPLAB&nbsp;ICD&nbsp;2&nbsp;Ready<br /><br /><br />用ICD&nbsp;2燒錄程式失敗。用ICD&nbsp;2供電和目標板供電都試過,出現的問題是一樣的,連接沒有問題,IC都能找到,但燒錄時就是會出錯,且錯誤代號都為:ICD0161,不知有誰碰到過類似的問題,請指教。
xieyuanbin 发表于 2007-4-25 12:33 | 显示全部楼层
就是校验错
也就是说,你程序没写进去,或者说,你响应的IO口上有较大电容。
 楼主| lurker_soo 发表于 2007-4-27 13:20 | 显示全部楼层
問題已解決
問題已解決,換用MPLAB&nbsp;IDE&nbsp;V7.50即可!有碰到類似問題的朋友,可依此試試看!
