[Atmel] 用AtmelStudio6.2跑mega16例程(72)控制直流电机
1141|1
 楼主| ddllxxrr 发表于 2014-12-16 21:31 | 显示全部楼层 |阅读模式
运行本例时,按下K1可使直流电机正转,按下K2可使直流电机反转,按下K3时停止。
Proteus运行时截图:
Atmel Studio6.2 编译通过截图:
程序清单:
  1. /*
  2. * GccApplication35.c
  3. *
  4. * Created: 2014-12-16 20:52:59
  5. *  Author: Administrator
  6. */
  7. #define  F_CPU 4000000UL
  8. #include <util/delay.h>
  9. #include <avr/io.h>
  10. #include <stdint.h>
  11. #define K1_DOWN()((PIND & _BV(PD1))==0x00)
  12. #define K2_DOWN()((PIND& _BV(PD4))==0x00)
  13. #define K3_DOWN() ((PIND & _BV(PD7))==0x00)
  14. #define LED1_ON() (PORTC = 0B11111110)
  15. #define LED2_ON() (PORTC = 0B11111101)
  16. #define LED3_ON() (PORTC = 0B11111011)
  17. #define MA_0() (PORTB &= ~_BV(PB2))
  18. #define MA_1() (PORTB |= _BV(PB2))
  19. #define MB_0() (PORTB &= ~_BV(PB1))
  20. #define MB_1() (PORTB |= _BV(PB1))
  21. int main(void)
  22. {
  23.     DDRB = 0xFF;PORTB = 0xFF;
  24.         DDRC = 0xFF;PORTC = 0xFF;
  25.         DDRD = 0x00;PORTD = 0xFF;
  26.         LED3_ON();
  27.         while(1)
  28.     {
  29.         if(K1_DOWN())
  30.                 {
  31.                     while(K1_DOWN());
  32.                         LED1_ON();MA_0();MB_1();
  33.                 }
  34.                 if(K2_DOWN())
  35.                 {
  36.                     while(K2_DOWN());
  37.                         LED2_ON(); MA_1();MB_0();
  38.                 }
  39.                 if(K3_DOWN())
  40.                 {
  41.                     while(K3_DOWN())
  42.                         LED3_ON();MA_0();MB_0();
  43.                 }
  44.     }
  45. }
XHB7906021 发表于 2016-3-1 22:01 | 显示全部楼层
要是能把PROTEUS 及ATIMEL ST6。2程序,全部都有传上来,那更好。多谢了!!!:)
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2404
