 接上贴哈,上贴向串口发了一串字符串。我今天苦想了半天,就象发一个字符终于搞定哈
 首先接着昨天的程序,我加了我要发的一个变量,把它赋值为0x55,为什么要用0x55,因为它是01准确间隔,用它的可以看出速率准不谁!!!!!
 我加的只有两句:其它不变
 uint8_t mystring = 0x55;
 usart_write_buffer_wait(&usart_instance, string, sizeof(string));
 我为什么这么做呢,我是想往printf上靠,究竟能不能实现,且听下回分解。
 程序清单如下:
 * \file
 * \brief Empty user application template
 * \mainpage User Application template doxygen documentation
 * \par Empty user application template
 * This is a bare minimum user application template.
 * For documentation of the board, go \ref group_common_boards "here" for a link
 * to the board-specific documentation.
 * \par Content
 * -# Include the ASF header files (through asf.h)
 * -# Minimal main function that starts with a call to system_init()
 * -# Basic usage of on-board LED and button
 * -# "Insert application code here" comment
 * Include header files for all drivers that have been imported from
 * Atmel Software Framework (ASF).
#include <asf.h>
void configure_usart(void);
struct usart_module usart_instance;
         struct usart_config config_usart;
         usart_get_config_defaults(&config_usart);
         config_usart.baudrate    = 9600;
         config_usart.mux_setting = EXT3_UART_SERCOM_MUX_SETTING;
         config_usart.pinmux_pad0 = EXT3_UART_SERCOM_PINMUX_PAD0;
         config_usart.pinmux_pad1 = EXT3_UART_SERCOM_PINMUX_PAD1;
         config_usart.pinmux_pad2 = EXT3_UART_SERCOM_PINMUX_PAD2;
         config_usart.pinmux_pad3 = EXT3_UART_SERCOM_PINMUX_PAD3;
         while (usart_init(&usart_instance, EXT3_UART_MODULE, &config_usart) != STATUS_OK)
          usart_enable(&usart_instance);
int main (void)
        system_init();
        configure_usart();
        uint8_t string[] = "Hello World!\r\n";
        uint16_t temp;
        while (true)
                                usart_write_buffer_wait(&usart_instance, &mystring, sizeof(        mystring));
                                if (usart_read_wait(&usart_instance, &temp) == STATUS_OK)
                {            while (usart_write_wait(&usart_instance, temp) != STATUS_OK)
