首先建立ASF工程,然后工程中加入DMAC模块。
然后打开ASF EXPLORER 打开快速指导
然后按照快速指导来形成程序。
然后编译
当编译通过时,在DMAC传输完成后边打一个断点。
则目地数组内也有相应的数据:
时钟没有特别要求。
程序清单如下:
- * \file
- * \brief Empty user application template
- * \mainpage User Application template doxygen documentation
- * \par Empty user application template
- * This is a bare minimum user application template.
- * For documentation of the board, go \ref group_common_boards "here" for a link
- * to the board-specific documentation.
- * \par Content
- * -# Include the ASF header files (through asf.h)
- * -# Minimal main function that starts with a call to system_init()
- * -# Basic usage of on-board LED and button
- * -# "Insert application code here" comment
- * Include header files for all drivers that have been imported from
- * Atmel Software Framework (ASF).
- * Support and FAQ: visit <a href="http://www.atmel.com/design-support/">Atmel Support</a>
- #include <asf.h>
- struct dma_resource example_resource;
- #define DATA_LENGTH (512)
- static uint8_t source_memory[DATA_LENGTH];
- static uint8_t destination_memory[DATA_LENGTH];
- static volatile bool transfer_is_done = false;
- COMPILER_ALIGNED(16)
- DmacDescriptor example_descriptor;
- static void transfer_done( const struct dma_resource* const resource )
- { transfer_is_done = true;}
- static void configure_dma_resource(struct dma_resource *resource)
- struct dma_resource_config config;
- dma_get_config_defaults(&config);
- dma_allocate(resource, &config);}
- static void setup_transfer_descriptor(DmacDescriptor *descriptor )
- struct dma_descriptor_config descriptor_config;
- dma_descriptor_get_config_defaults(&descriptor_config);
- descriptor_config.block_transfer_count = sizeof(source_memory);
- descriptor_config.source_address = (uint32_t)source_memory + sizeof(source_memory);
- descriptor_config.destination_address = (uint32_t)destination_memory + sizeof(source_memory);
- dma_descriptor_create(descriptor, &descriptor_config);}
- int main (void)
- system_init();
- configure_dma_resource(&example_resource);
- setup_transfer_descriptor(&example_descriptor);
- dma_add_descriptor(&example_resource, &example_descriptor);
- dma_register_callback(&example_resource, transfer_done, DMA_CALLBACK_TRANSFER_DONE);
- dma_enable_callback(&example_resource, DMA_CALLBACK_TRANSFER_DONE);
- for (uint32_t i = 0; i < DATA_LENGTH; i++)
- { source_memory[i] = i; }
- dma_start_transfer_job(&example_resource);
- dma_trigger_transfer(&example_resource);
- while (!transfer_is_done) { /* Wait for transfer done */ }
- while (true) { /* Nothing to do */ }
