- #define PLLCTL_SETTING CLK_PLLCTL_72MHz_HXT
- #define PLL_CLOCK 72000000
- uint32_t volatile u32IsTestOver = 0;
- void SYS_Init(void)
- /* Init System Clock */
- /* Enable HIRC, HXT and LXT clock */
- CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
- CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
- CLK_EnableXtalRC(CLK_PWRCTL_LXTEN_Msk);
- /* Wait for HIRC, HXT and LXT clock ready */
- CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
- CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
- CLK_WaitClockReady(CLK_STATUS_LXTSTB_Msk);
- /* Select HCLK clock source as HIRC and and HCLK clock divider as 1 */
- CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
- /* Set core clock as PLL_CLOCK from PLL */
- CLK_SetCoreClock(PLL_CLOCK);
- CLK_EnableModuleClock(UART0_MODULE);
- CLK_EnableModuleClock(PDMA_MODULE);
- /* Init I/O Multi-function */
- /* Set PD multi-function pins for UART0 RXD and TXD */
- SYS->GPD_MFPL &= ~(SYS_GPD_MFPL_PD0MFP_Msk | SYS_GPD_MFPL_PD1MFP_Msk);
- SYS->GPD_MFPL |= (SYS_GPD_MFPL_PD0MFP_UART0_RXD | SYS_GPD_MFPL_PD1MFP_UART0_TXD);
- uint16_t usart_dma_buf[100]= {0x00};
- uint8_t PDMA_TEST_LENGTH=100;
- int main()
- int8_t item[100];
- uint8_t i;
- /* Unlock protected registers */
- SYS_UnlockReg();
- SYS_Init();
- /* Lock protected registers */
- SYS_LockReg();
- UART_Open(UART0, 115200);
- for(i=0; i<100; i++)
- usart_dma_buf[i]=i;
- PDMA_Open(0x4);
- PDMA_SetTransferCnt(2, PDMA_WIDTH_8, PDMA_TEST_LENGTH);
- /* transfer width is one word(32 bit) */
- PDMA_SetTransferAddr(2, (uint32_t)(&usart_dma_buf[PDMA_TEST_LENGTH]), PDMA_SAR_INC, UART0_BASE, PDMA_DAR_FIX);
- PDMA_SetTransferMode(2, PDMA_UART0_TX, FALSE, 0);
- //burst size is 4
- PDMA_SetBurstType(2, PDMA_REQ_SINGLE, 0);
- PDMA_EnableInt(2, PDMA_INT_TRANS_DONE);
- NVIC_EnableIRQ(PDMA_IRQn);
- UART0->INTEN|=UART_INTEN_TXPDMAEN_Msk;
- u32IsTestOver=0;
- Delay_Init();
- EXTI_Init();
- printf("\r\n");
- while(u32IsTestOver == 0);
- if(u32IsTestOver == 1)
- printf("test done...\r\n");
- else if(u32IsTestOver == 2)
- printf("target abort...\r\n");
- printf("Simple Demo Code\r\n");
- printf("Please Input Any Key\r\n");
- GPIO_SetMode(PC, BIT9, GPIO_MODE_OUTPUT);
- while(1)
- /* Get input character */
- scanf("%s",item);
- /* Print input character back */
- printf("%s\r\n", item);
- void PDMA_IRQHandler(void)
- uint32_t status = PDMA_GET_INT_STATUS();
- if (status & 0x1) { /* abort */
- printf("target abort interrupt !!\n");
- if (PDMA_GET_ABORT_STS() & 0x4)
- u32IsTestOver = 2;
- PDMA_CLR_ABORT_FLAG(PDMA_ABTSTS_ABTIFn_Msk);
- } else if (status & 0x2) { /* done */
- if ( PDMA_GET_TD_STS() & (1 << 2)) {
- u32IsTestOver = 1;
- PDMA_CLR_TD_FLAG(PDMA_TDSTS_TDIFn_Msk);
- } else if (status & 0x300) { /* channel 2 timeout */
- printf("timeout interrupt !!\n");
- u32IsTestOver = 3;
- PDMA_CLR_TMOUT_FLAG(0);
- PDMA_CLR_TMOUT_FLAG(1);
- } else
- printf("unknown interrupt !!\n");
按照例程写了一个串口DMA,UART0_TX的DMA,使能了中断,运行时也能进到中断,检测到了发送完成的标志,但是电脑的调试助手收不到DMA发送的数据,调试的数据都能收到,收到的数据如下图所示:
请问下这个问题怎么解决!
