编译不能通过
831|3
 楼主| happy_10 发表于 2015-2-11 20:49 | 显示全部楼层 |阅读模式
** ERROR #A51 IN 3094 (E:\PSOC\My-shiyan\out_io\out_io.cydsn\main.src, LINE 118): TARGET OUT OF RANGE
The command 'Ax51.exe' failed with exit code '2'.
wenfen 发表于 2015-2-11 20:50 | 显示全部楼层
工程代码能发上来么?
 楼主| happy_10 发表于 2015-2-11 20:53 | 显示全部楼层
代码如下:也不知道错误信息中的不知道code '2'代表什么?
#include <device.h>
void main()
    /* Place your initialization/startup code here (e.g. MyInst_Start()) */
    /* CyGlobalIntEnable; */ /* Uncomment this line to enable global interrupts. */
    for(;;)
SFRPRT2SEL |= 0xFF; //enables the control of the port
#pragma asm
loop:
mov A, SFRPRT2PS ; 1 Clock Reads the value of port2
inc A ; 1 Clock Adds 1
mov SFRPRT2DR,A ; 1 Clock Writes to port2
REPT 992 ; delay for 992 clock cycles
NOP ; 1*992=992 Clock Cycles
ENDM
jmp loop ; 5 clock
#pragma endasm
/* [] END OF FILE */
wenfen 发表于 2015-2-11 20:54 | 显示全部楼层
估计是你没有enable assembly for main.c file. Creator > WorkSpace explorer > Project > main.c > right clicking > Building setting > Compiler > Inline Assemble > Enable(disable in default).
