 这个程序是调用,CMSIS中的滴答时钟来实现1秒钟延时。
 首选建立ASF工程,然后选择SAM4S的芯片,我这里选择ATSAM4SD32C
 然后系统自动建立程序框架,并且还有LED程序。
 然后加入Delay routines模块,
 最后键入以下程序:
 * \file
 * \brief Empty user application template
 * \mainpage User Application template doxygen documentation
 * \par Empty user application template
 * This is a bare minimum user application template.
 * For documentation of the board, go \ref group_common_boards "here" for a link
 * to the board-specific documentation.
 * \par Content
 * -# Include the ASF header files (through asf.h)
 * -# Minimal main function that starts with a call to board_init()
 * -# Basic usage of on-board LED and button
 * -# "Insert application code here" comment
 * Include header files for all drivers that have been imported from
 * Atmel Software Framework (ASF).
 * Support and FAQ: visit <a href="http://www.atmel.com/design-support/">Atmel Support</a>
#include <asf.h>
#include "conf_board.h"
static volatile uint32_t ticks = 0U;
void SysTick_Handler(void)
        ticks ++;
int main (void)
        sysclk_init();
        board_init();
        // Insert application code here, after the board has been initialized.
     if(SysTick_Config(sysclk_get_cpu_hz()/(uint32_t)1000))
                 while(1)
        // This skeleton code simply sets the LED to the state of the button.
        while (1) {
                // Is button pressed?
                //if (ioport_get_pin_level(BUTTON_0_PIN) == BUTTON_0_ACTIVE) {
                        // Yes, so turn LED on.
                        ioport_set_pin_level(LED_0_PIN, LED_0_ACTIVE);
                        delay_ms((uint32_t)1000);
                //} else {
                        // No, so turn LED off.
                        ioport_set_pin_level(LED_0_PIN, !LED_0_ACTIVE);
 编译通过时,下进开发板,发现LED0每一秒换一下亮灭的状态。
 这个程序就是每记到1000就换一下状态。
