作读卡器开发的毕看!!
5865|19
 楼主| jt4117 发表于 2007-1-15 14:00 | 显示全部楼层 |阅读模式
价格公道,如有兴趣,请留下联系方式。<br />Features:<br />32-bit&nbsp;ARM7TDMI&nbsp;RISC&nbsp;static&nbsp;CMOS&nbsp;CPU&nbsp;core&nbsp;(Running&nbsp;up&nbsp;to&nbsp;60&nbsp;MHz)<br />8Kbytes&nbsp;combined&nbsp;instruction/data&nbsp;cache<br />Memory&nbsp;management&nbsp;unit<br />Supports&nbsp;Little-endian&nbsp;operating&nbsp;system<br />8Kbytes&nbsp;SRAM&nbsp;for&nbsp;internal&nbsp;buffer&nbsp;memory<br />2Kbytes&nbsp;Boot&nbsp;ROM<br />On-chip&nbsp;peripherals&nbsp;with&nbsp;individual&nbsp;power-down:<br />&nbsp;Memory&nbsp;controller&nbsp;for&nbsp;ROM(x8,16),&nbsp;Flash(x8,16),&nbsp;SRAM(x8,16),&nbsp;SDRAM(x16)<br />&nbsp;5-State&nbsp;Power&nbsp;management&nbsp;unit&nbsp;(Sofrware&nbsp;selectable&nbsp;Clock&nbsp;Frequency)<br />&nbsp;Interrupt&nbsp;Controller<br />&nbsp;LCD&nbsp;Controller&nbsp;for&nbsp;color&nbsp;and&nbsp;mono&nbsp;STN<br />&nbsp;USB&nbsp;1.1(slave)<br />&nbsp;Two&nbsp;Smart&nbsp;Card&nbsp;Interface&nbsp;(UART&nbsp;0,1)<br />&nbsp;Two&nbsp;UART&nbsp;(UART&nbsp;2,3)<br />&nbsp;One&nbsp;SIR&nbsp;support&nbsp;UART&nbsp;(UART4)<br />&nbsp;One&nbsp;Modem&nbsp;support&nbsp;UART&nbsp;(UART5)<br />&nbsp;Four&nbsp;16-bit&nbsp;Timer&nbsp;Channels&nbsp;(with&nbsp;Output&nbsp;Port)<br />&nbsp;Two&nbsp;16-bit&nbsp;PWM&nbsp;Channels&nbsp;(with&nbsp;Output&nbsp;Port)<br />&nbsp;Programmable&nbsp;WatchDog&nbsp;Timer&nbsp;with&nbsp;On-chip&nbsp;Oscillator<br />&nbsp;Real-time&nbsp;clock&nbsp;(32.768kHz&nbsp;oscillator)&nbsp;with&nbsp;separated&nbsp;Vcc<br />&nbsp;Matrix&nbsp;Keyboard&nbsp;control&nbsp;interface&nbsp;(6x6)<br />&nbsp;97&nbsp;Programmable&nbsp;GPIO<br />&nbsp;One&nbsp;2-Wire&nbsp;Serial&nbsp;Bus&nbsp;Interface<br />&nbsp;2-Channel&nbsp;Master/Slave&nbsp;SSI&nbsp;(SPI)<br />&nbsp;SMC&nbsp;Card&nbsp;Interface<br />&nbsp;On-chip&nbsp;3-Channel&nbsp;10-bit&nbsp;ADC<br />JTAG&nbsp;debug&nbsp;interface&nbsp;and&nbsp;boundary&nbsp;scan<br />0.35um&nbsp;CMOS&nbsp;Process<br />3.3V&nbsp;supply&nbsp;voltage<br />208-pin&nbsp;LQFP&nbsp;/&nbsp;CABGA&nbsp;package<br />Low&nbsp;power&nbsp;consumption
 楼主| jt4117 发表于 2007-1-15 14:01 | 显示全部楼层
一款非常适合做读卡器方案的arm芯片!!
redleafzzh 发表于 2007-1-15 14:14 | 显示全部楼层
大概价格多少呢?
foyyof 发表于 2007-1-15 14:16 | 显示全部楼层
it looks good。
不过连个型号都没!
 楼主| jt4117 发表于 2007-1-15 14:20 | 显示全部楼层
如果
 楼主| jt4117 发表于 2007-1-15 14:25 | 显示全部楼层
我们是abov semiconductor
韩国芯片,芯片型号为hms30c7210.价格在&nbsp;$5左右。<br />如有兴趣,可先留下电话和mail。<br /><br /><br />
 楼主| jt4117 发表于 2007-1-15 14:30 | 显示全部楼层
我可以把芯片datasheet先发过去。
 楼主| jt4117 发表于 2007-1-15 14:39 | 显示全部楼层
公司网址
http://www.abov.co.kr/abov_eng/product/8bit.php?sltCategory=32-bit%20ARM
foyyof 发表于 2007-1-15 14:46 | 显示全部楼层
恩,不错,先下个手册看看。
 楼主| jt4117 发表于 2007-1-15 14:48 | 显示全部楼层
忘了说....
我们在深圳福田区。
 楼主| jt4117 发表于 2007-1-15 15:28 | 显示全部楼层
如果公司在深圳的话,我们可以面谈。
xwj 发表于 2007-1-15 16:41 | 显示全部楼层
价格太高!!!
 楼主| jt4117 发表于 2007-1-15 16:46 | 显示全部楼层
这个只是初步报价。
如果有感兴趣的话,可以面谈。
whereis 发表于 2007-1-15 19:02 | 显示全部楼层
这完全是老技术了。<br /><br />-----------------------------------------<br />0.35um&nbsp;CMOS&nbsp;Process<br />
 楼主| jt4117 发表于 2007-1-16 08:40 | 显示全部楼层
可以先看一下datasheet,老技术也好,新技术也好,最主要是
zlei 发表于 2007-1-16 09:20 | 显示全部楼层
hynix的arm不好买
价格有这么高.<br /><br />连ATMEL出的ARM926EJS内核的9260,也只要6美刀了,海力士的ARM7还要这么贵.
 楼主| jt4117 发表于 2007-1-16 10:00 | 显示全部楼层
回17楼
公司现在主推HMS30C7210.HMS30C7202的具体价格不便在网上公布。可否留下联系方式?
 楼主| jt4117 发表于 2007-1-16 10:03 | 显示全部楼层
这个网址是7202的datasheet
http://www.abov.co.kr/abov_eng/product/8bit_prodeta.php?strTbName=tblProduct&strMode=content&intSeqNo=249&intReadNum=&intPage=1&sltSearchField=&txtSearchString=&sltSearchField2=&intSortNum=2&sltCategory=&sltCategory=32-bit%20ARM
arm_fans 发表于 2007-1-16 12:29 | 显示全部楼层
回复
贴主啊,你不方便公开价格,我们也不方便公布联系信息啊,你为什么不留个联系信息啊?邮箱、QQ都行啊。
 楼主| jt4117 发表于 2007-1-16 12:44 | 显示全部楼层
不好意思,我的方式
公司邮箱不方便公布。<br />jt4117@163.com<br />
