关于最近driver lib的库函数调用问题
1797|4
 楼主| xuanfeng0109 发表于 2015-4-25 11:32 | 显示全部楼层 |阅读模式
我最近在跟着论坛学习driver lib的库函数调用,在读取iic的时候,不知道如何来使用这些封装好的函数,这是我改的官方的,大家帮忙看看哈,不知道怎么了,目前没搞定,
#include "driverlib.h"
#define SLAVE_ADDRESS 0x80
uint8_t transmitData0;
uint8_t transmitData1;
uint8_t receivedData;
void main(void)
    //Stop WDT
    WDT_A_hold(WDT_A_BASE);
    //Assign I2C pins to USCI_B0
    GPIO_setAsPeripheralModuleFunctionInputPin(
        GPIO_PORT_P3,
        GPIO_PIN0 + GPIO_PIN1
    //Initialize transmit data packet
    transmitData0 = 0x81;
    transmitData0 = 0xE0;
    //Initialize Master
    USCI_B_I2C_initMasterParam param = {0};
    param.selectClockSource = USCI_B_I2C_CLOCKSOURCE_SMCLK;
    param.i2cClk = UCS_getSMCLK();
    param.dataRate = USCI_B_I2C_SET_DATA_RATE_100KBPS;
    USCI_B_I2C_initMaster(USCI_B0_BASE, &param);
    //Specify slave address
    USCI_B_I2C_setSlaveAddress(USCI_B0_BASE,
                               SLAVE_ADDRESS
    //Set in transmit mode
    USCI_B_I2C_setMode(USCI_B0_BASE,
                       USCI_B_I2C_TRANSMIT_MODE
    //Enable I2C Module to start operations
    USCI_B_I2C_enable(USCI_B0_BASE);
    USCI_B_I2C_clearInterrupt(USCI_B0_BASE,
                                 USCI_B_I2C_RECEIVE_INTERRUPT
       USCI_B_I2C_enableInterrupt(USCI_B0_BASE,
        //Send single byte data.
        USCI_B_I2C_masterSendSingleByte(USCI_B0_BASE,
                                        transmitData0
        //Delay until transmission completes
        while(USCI_B_I2C_isBusBusy(USCI_B0_BASE))
                                        transmitData1
               USCI_B_I2C_masterReceiveSingleStart(USCI_B0_BASE);
               receivedData = USCI_B_I2C_masterReceiveSingle(
                           USCI_B0_BASE);
#if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__)
#pragma vector=USCI_B0_VECTOR
__interrupt
#elif defined(__GNUC__)
__attribute__((interrupt(USCI_B0_VECTOR)))
#endif
void USCI_B0_ISR(void)
dirtwillfly 发表于 2015-4-25 15:20 | 显示全部楼层
你用的哪个msp430?
quray1985 发表于 2015-4-29 08:39 | 显示全部楼层
楼主发帖的时候,选择代码模式可读性更强一些
 楼主| xuanfeng0109 发表于 2015-4-30 09:11 | 显示全部楼层
你用的哪个msp430?
我用的msp430F5229使用硬件iic操作一个温湿度传感器,si7020,最近比较忙,没来论坛,:$
好的,没注意这个,下次一定注意
