Flash Magic的下载HEX文件时,怎么咯~~~
4748|2
 楼主| Goto_ARM 发表于 2008-9-26 16:30 | 显示全部楼层 |阅读模式
高手帮帮忙~~~~在使用Flash&nbsp;Magic&nbsp;下载&nbsp;hex文件<br /><br />出现的错误:<br /><br />1、在单击&nbsp;START准备下载程序时&nbsp;出现一下提示:<br /><br />The&nbsp;device&nbsp;signature&nbsp;does&nbsp;not&nbsp;match&nbsp;the&nbsp;expected&nbsp;values&nbsp;.&nbsp;Accessing&nbsp;a&nbsp;device&nbsp;using&nbsp;the&nbsp;wrong&nbsp;protocol&nbsp;could&nbsp;render&nbsp;the&nbsp;device&nbsp;unusable.&nbsp;Do&nbsp;you&nbsp;want&nbsp;to&nbsp;continue&nbsp;?&nbsp;yes&nbsp;no<br /><br />当我不管它继续下载时:&nbsp;程序能够被正常的运行。&nbsp;<br /><br />此时其Flash&nbsp;Magic&nbsp;的选项是:<br /><br />[&nbsp;&gt&nbsp;]&nbsp;Verify&nbsp;after&nbsp;programming&nbsp;<br /><br />[&nbsp;&gt&nbsp;]&nbsp;Erase&nbsp;all&nbsp;Flash+Code&nbsp;Rd&nbsp;Prot<br /><br />2、同样出现以上提示,但是程序运行不正常咯.~<br /><br />此时其Flash&nbsp;Magic&nbsp;的选项是:<br /><br />[&nbsp;&gt&nbsp;]&nbsp;Verify&nbsp;after&nbsp;programming&nbsp;<br /><br />[&nbsp;&gt&nbsp;]&nbsp;Erase&nbsp;all&nbsp;Flash+Code&nbsp;Rd&nbsp;Prot<br /><br />[&nbsp;&gt&nbsp;]&nbsp;Set&nbsp;Code&nbsp;Read&nbsp;Prot&nbsp;就多了这个选项就出现了错误<br /><br />请高手指教~~~<br />
john_light 发表于 2008-9-26 16:51 | 显示全部楼层
芯片型号选错了吧
 楼主| Goto_ARM 发表于 2008-9-27 08:59 | 显示全部楼层
没有
我前面说过:我在&nbsp;没有选&nbsp;[&nbsp;&gt&nbsp;]&nbsp;Set&nbsp;Code&nbsp;Read&nbsp;Prot时,我已经能够下载,并且能够正确使用了啊?&nbsp;&nbsp;但是&nbsp;选择了&nbsp;[&nbsp;&gt&nbsp;]&nbsp;Set&nbsp;Code&nbsp;Read&nbsp;Prot时,则运行一点都不正常的哈&nbsp;
