[Atmel] Arduino Boards for Makers
1042|1
 楼主| ddllxxrr 发表于 2015-6-2 21:09 | 显示全部楼层 |阅读模式
Today, both Atmel AVR 8-bit MCUs and Atmel 32-bit ARM®-based MCUs power a variety of Arduino’s easy-to-use boards including:
  • Arduino Zero – Based on the Atmel | SMART SAMD21 MCU, the Zero is a simple, elegant and powerful 32-bit extension of the platform aiming to provide creative individuals the potential to realize truly innovative ideas for smart IoT devices, wearable technology, high-tech automation, robotics and projects not yet imagined.
  • Arduino Uno - Based on the Atmel AVR ATmega328, the Uno board is a low-cost Arduino board with a simpler circuit. The software onboard includes a USB driver that can simulate a mouse, keyboard and serial port. In addition, the bootloader includes a serial port and USB mass storage driver.
  • Arduino Due – Based on an Atmel | SMART SAM3 MCU, the Due board is ideal for home automation projects and can run up to 96MHz.
  • Arduino Wi-Fi Shield 101– Built on an easy-to-use extension that can be seamlessly connected to any Arduino board, the Wi-Fi Shield 101 is powered by the Atmel SmartConnect wireless network controller and an Atmel CryptoAuthentication™ ATECC108 device.
  • Arduino Leonardo – Based on the Atmel megaAVR® ATmega32U4, the Arduino Leonardo is a low-cost Arduino board. It has the same shape and connectors as the UNO board, but it has a simpler circuit. On the software side it provides a USB driver able to simulate a mouse, a keyboard, and a serial port.
吕工程 发表于 2015-6-3 08:23 | 显示全部楼层
高科技产品,值得看看。
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2404
