关于linux内核移植的问题1
861|0
 楼主| wangxd5429 发表于 2015-6-26 10:10 | 显示全部楼层 |阅读模式
各位高手,小弟正在移植linux内核到友善之臂的mini6410平台,linux内核版本2.6.39。移植完成NAND FLASH驱动后,进行测试,发现系统未运行s3c6410_nand_probe函数。请教其中的原因,谢谢。平台设备已经添加,代码如下:
         代码所在文件:arch/arm/plat_samsung/dev-nand.c。
         static struct resource s3c_nand_resource[] = {
         [0] = {
                   .start = S3C_PA_NAND,
                   .end   = S3C_PA_NAND + SZ_1M,
                   .flags = IORESOURCE_MEM,
struct platform_device s3c_device_nand = {
                  .name                   = "s3c6410-nand",
                  .id                = -1,
                  .num_resources           = ARRAY_SIZE(s3c_nand_resource),
                  .resource     = s3c_nand_resource,
代码所在文件:arch/arm/mach-s3c64xx/mach-th6410.c。
static struct platform_device *th6410_devices[] __initdata = {
         &s3c_device_nand, /*添加NAND设备*/
static void __init th6410_machine_init(void)
               s3c_ide_set_platdata(&th6410_ide_pdata);
               ret = platform_add_devices(th6410_devices, ARRAY_SIZE(th6410_devices));
               if (ret == 0)
                        printk ("\n platform_add_devices = 0 \n");
                  //BUG_ON (!ret);
         驱动程序已经添加,代码如下:
         代码所在文件:drivers/mtd/nand/s3c_nand.c。
         staticstruct platform_driver s3c6410_nand_driver= {
                  .probe                 =s3c6410_nand_probe,
                  .remove             =s3c_nand_remove,
                  .suspend   = s3c_nand_suspend,
                  .resume              =s3c_nand_resume,
                  .driver                 ={
                            .name       ="s3c6410-nand",
                            .owner       =THIS_MODULE,
static int __init s3c_nand_init(void)
               printk("S3C NAND Driver, (c) 2008 Samsung Electronics\n");
               platform_driver_register(&s3c2450_nand_driver);
               platform_driver_register(&s3c6400_nand_driver);
               platform_driver_register(&s3c6410_nand_driver);
               return platform_driver_register(&s5pc100_nand_driver);
//        returnplatform_driver_register(&s3c6410_nand_driver);
