[ARM7]
LPC2364实现流水灯
610|0
小弟刚接触嵌入式   现在有一块LPC2364芯片的开发板    想实现流水灯    想控制P1.0  P1.1  P1.4 P1.8  端口的灯亮
我的程序是
#include "config.h"
#define LED1 (1<<0)
#define LED2 (1<<1)
#define LED3 (1<<4)
#define LED4 (1<<8)
void delay(uint32 num)
{  while(num!=0)
        num--;
int main(void)
         PINSEL0=0x00000000;
         PINSEL1=0x00000000;
         IO0DIR=0xffffffff;
         IO0SET=0xffffffff;
        while(1)
                  IO0CLR=LED1;
                  delay(500000);
                  IO0SET=LED1;
                  IO0CLR=LED2;
                  delay(500000);
                  IO0SET=LED2;
                  IO0CLR=LED3;
                  delay(500000);
                  IO0SET=LED3;
                  IO0CLR=LED4;
                  delay(500000);
                  IO0SET=LED4;
请问各位大神哪里需要修改????、   谢谢!
